Topic "problem in sync process using scripting"
achanda
My target is to sync the files of two servers using scripting.
1. Source- Files in RHEL server generated by an application in a particular directory.
2. Target- A Windows 2003 (SP 2) server folder.
It works fine for all except the file which is currently getting updated by the application. It just skips that file and syncs all other files which are not in use by the application at that point of time.
Is it possible to sync the current file also. When I tried using the GUI it works. I upgraded to WinSCP 5.7.7 from previous version but still no luck.
Cheers,
Arnab
Please attach log files both from the GUI and the script, showing the different behavior.
achanda
I have attached the logs for both the mode.
If you kindly see logs, the file which is used by the application currently (XXXXX_373.log) is not getting synced while it running as a script. But no issues during the manual process.
Many Thanks in advance.
Cheers,
Arnab
WinSCPLog.zip (8.65 KB) Private file
Description: I have modified the files to overwrite some of the non shareable information
In GUI you are synchronizing a local directory D:\Applications, while in the script you are synchronizing D:\Applications\GenesysOutboundReporter\dataFolder\auditData.
achanda
Thanks for the reply.
The folder used for synchronization using GUI is just for example and to simulate the problem. I can assure you that both the folder contains the identical files. Tried both the folders having older files as well as making them empty.
Cheers,
Arnab
Sorry, I want to see log files for the identical folders. Your reassurance won't help me debugging your problem.
achanda
Attached the logs.
Cheers,
Arnab
WinSCP Logs.zip (17.5 KB) Private file
Description: WINSCP logs for GUI & SCRIPT
The only difference I see is that in scripting the CallStats_AuditLog_DC1.20160321_143940_282.log was excluded:
Quote:
. 2016-03-21 15:40:45.439 Remote file '<Unix Path>/CallStats_AuditLog/CallStats_AuditLog_DC1.20160321_143940_282.log' [2016-03-21T15:40:52.000Z] [3175341] excluded from synchronization
It's because you have a file mask *.log<=0D. It effectively says to exclude all "future" files. The file has timestamp 15:40:52, while the current time is 15:40:45.
achanda
Thanks for the update.
Modified that part and works absolutely fine.
Many thanks for all your help.
Cheers,
Arnab
