Topic "How to use get -delete ... to delete files only and not directories"
othmane
I want a solution please of my problem..
I want to download files from FTP and make directories empty .
Example :
file0,DIR1(file1,file2,DIR2(file3 ...), ...) ---> DIR1(DIR2(empty))
thank you VERY MUCH
See http://winscp.net/eng/docs/library_example_moves_files_keeping_directory_structure
othmane
Thank you,
I found a script which gets files and deletes them after succesfull download, it keeps the local directories hierarchy by default Smile
try
    # Load WinSCP .NET assembly
    Add-Type -Path "WinSCPnet.dll"
    # Setup session options
        Protocol = [WinSCP.Protocol]::ftp
        FtpSecure = [WinSCP.FtpSecure]::Implicit
        HostName = "xxxx"
        UserName = "xxxx"
        Password = "xxxxx"
        PortNumber = "990"
        FtpMode = "Passive"
        TlsHostCertificateFingerprint = "xxxxxx"
    $session.SessionLogPath = "x:\xxxx.log"
    try
        # Connect
        # Download files
        $transferOptions.TransferMode = [WinSCP.TransferMode]::Binary
        $transferOptions.FileMask = "*"
        $transferOptions.PreserveTimestamp = $true
        $transferResult = $session.GetFiles("/","x:\xxxx", $False, $transferOptions)
        # Throw on any error
        $transferResult.Check()
        # Print results
        foreach ($transfer in $transferResult.Transfers)
            Write-Host ("Download of {0} succeeded" -f $transfer.FileName)
           #$removalResult = $session.RemoveFiles($session.EscapeFileMask($transfer.FileName))
            #if ($removalResult.IsSuccess)
                    #Write-Host ("Removing of file {0} succeeded" -f
                        #$transfer.FileName)
                #else
                    #Write-Host ("Removing of file {0} failed" -f
    finally
        # Disconnect, clean up
        $session.Dispose()
    exit 0
catch [Exception]
    Write-Host $_.Exception.Message
    exit 1
[/code]
