Topic "WinSCP 5.7.2 not launching"
Adam_Allen
Hello, The problem I'm seeking help on is that WinSCP does not run
Version: 5.7.2
In trouble shooting, I determined that version 5.5.6 works ok on this machine. The problem seems to start with version 5.7.0
The OS is Windows POS Ready 2009 (XP Embedded)
I believe the transfer protocol is SFTP but we're not getting to that point.
Neither the GUI nor the scripting/automation seem to be working
The System EventLog shows this error: Application popup: WinSCP.exe - Application Error : The application failed to initialize properly (0x0000142) Click on OK to Terminate the application.
If any additional information is required please let me know. I'll do what I can to get it to you timely.
Thanks in Advance
Adam_Allen
Hi. Thanks for responding. Unfortunately the debug version fails the same way as the normal version and the debug file isn't created.
Thanks for the test. Can you try to find an exact version that introduced the problem? Was it really the 5.7? I.e. is the 5.6.5 working?
Adam_Allen
Good call. I tested from version 5.7.2 working my way back through previous versions. The problem seems to be versions 5.6.2 and later. 5.6.1 works, 5.6.2 doesn't.
Thanks.
I've sent you an email with links to few intermediate versions to narrow down the issue.
Adam_Allen
All 4 of the 562 builds failed the same way. I'm happy to try anything else you'd like me to.
Thanks for the tests. I've sent you few more builds. Please respond to the email.
