Topic "WinSCP error message: Timeout waiting for WinSCP to respond - WinSCP has not responded in time"
gtong
Hi
Everyday I got tasks that using powershell with WinSCP to automate downloading files from clients' sftp, they all work fine on most day, except Saturday (between 7:00 to 17:20)
the task that I run is basically looking for new files and then download it, it starts at 5:00 and repeat every 5 minutes for 12hrs in task scheduler and run as Administrator
On Saturday, it starts well (mean I got normal message) at 5:00am and until 7:00, I got this error message for every 5 minutes until 17:20
Error message: Timeout waiting for WinSCP to respond - WinSCP has not responded in time (response log file C:\Users\\AppData\Local\Temp\wscp.tmp was not created). This could indicate lack of write permissions to the log folder or problems starting WinSCP itself.
and after 17:20, I got the normal message:
'Synchronise the link file folder
WinSCP.SynchronizationResult
No files synchronised
COMPLETE'
I only got those error message on Saturday
do anyone know why and know how to fix it?
Thank you very much
Your duplicate post on Super User:
http://superuser.com/q/1059073/213663
There's nothing more to suggest that what is already in the answer on Super User.
Did you try to increase the timeout? Session.Timeout
http://winscp.net/eng/docs/library_session#timeout
