Topic "Move tabs in to second line instead of arrows"
SirWill
hey,
it would be great if there would be an option to disable the arrows and instead it will show the session tabs which don't fit below.
So that you have 2+ rows of tabs and you no longer need to scroll with the arrow buttons.
Thanks for your suggestion.
Will see if more people ask for this.
+1, working with 24/27" and can't have more than 10 servers visible :/
user 1234
2 row of tabs will be good, but it will be better, if you open many tabs, every tab should go smaller/thinner - like in firefox browser for example, it´s a good solution, IMHO
|server1|server2|server3|server4|server5|
|serv|serv|serv|serv|serv|serv|serv|serv|
because now, if you have many tabs open than it is hard to switch smoothly between all opened tabs.
For example if you have 40 tabs open in firefox than switching from tab40 to tab3 and than to tab29 and after to tab41 is very fast.
... and you can add an arrow on the left too.
Many thanks in advance if you can add this feature in the future, as standard or as option.
Thanks for your posts.
This request has been added to the tracker:
https://winscp.net/tracker/show_bug.cgi?id=1423
jrbrown00
SirWill wrote:
hey,
I would also like to see tabs on multiple rows. I often have 15-20 tabs open, often to different folders on the same server (source, logs, scripts, documentation, etc. We also have different servers for dev/prod/test, so the need for rows is enormous.
