Topic "CalculateFileChecksum returns "Operation not supported""
othmane
Hello
Checksum calculation is supported using ftps, but i am getting error ----> Operation not supported.
with the following line :
$remoteChecksum = [System.BitConverter]::ToString($session.CalculateFileChecksum($remoteChecksumAlg, $remotePath))
thanks
But only if the FTP server supports any of the HASH, XSHA1, XSHA256, XSHA512, MD5, XMD5 or XCRC commands. And your remoteChecksumAlg value (what is it?) matches the supported algorithm.
See http://winscp.net/eng/docs/protocols
Please attach a full session log file to confirm.
othmane
Ok,
It may be not supported, but I share anyway my script with the whole log session .
SCRIPT:
param (
    $localPath = "E:\xxxx\IMGP1280.JPG",
    $remotePath = "/IMGP1280.JPG",
    $logfileName = $(Get-Date -f "dd-MM-yyyy"),
    $remoteChecksumAlg = "HASH"
    # Load WinSCP .NET assembly
    Add-Type -Path "C:\FTPSynch\winscp577automation\WinSCPnet.dll"
# Setup session options
        Protocol = [WinSCP.Protocol]::ftp
        FtpSecure = [WinSCP.FtpSecure]::Implicit
        HostName = "xxxx.xxxx-xxxx.net"
        UserName = "xxxx@xxxx.xxxx-fichiers.net"
        Password = "xxxx"
        PortNumber = "990"
        FtpMode = "Passive"
        TlsHostCertificateFingerprint = "xxxx"
    $session.SessionLogPath = "C:\FTPSynch\Log_files\winscpCHECKsum.log"
try
    Write-Host $localPath
    # Calculate local file checksum
    $sha1 = [System.Security.Cryptography.SHA1]::Create()
    $localStream = [System.IO.File]::OpenRead($localPath)
    $localChecksum = [System.BitConverter]::ToString($sha1.ComputeHash($localStream))
    Write-Host $localChecksum
    try
    {        $session.Open($sessionOptions)
        Write-Host $remotePath
        # Calculate remote file checksum
        Write-Host $remoteChecksum
    finally
        # Disconnect, clean up
        $session.Dispose()
    # Compare cheksums
    if ($localChecksum -eq $remoteChecksum)
        Write-Host "Match"
        $result = 0
    else
        Write-Host "Does NOT match"
        $result = 1
catch [Exception]
    Write-Host $_.Exception.Message
    $result = 1
if ($pause)
exit $result
LOG
. 2016-04-01 16:24:35.721 WinSCP Version 5.7.7 (Build 6257) (OS 6.3.9600 - Windows Server 2012 R2 Standard)
. 2016-04-01 16:24:35.721 Configuration: nul
. 2016-04-01 16:24:35.721 Log level: Normal
. 2016-04-01 16:24:35.721 Local account: xxxxxxxxx\Administrateur
. 2016-04-01 16:24:35.721 Working directory: C:\FTPSynch\winscp577automation
. 2016-04-01 16:24:35.721 Process ID: 11168
. 2016-04-01 16:24:35.722 Command-line: "C:\FTPSynch\winscp577automation\winscp.exe" /xmllog="C:\Users\Administrateur\AppData\Local\Temp\2\wscp4B00.02DA4974.tmp" /xmlgroups /nointeractiveinput /dotnet=577  /ini=nul /log="C:\FTPSynch\Log_files\winscpCHECKsum.log"  /console /consoleinstance=_19200_14011464_481
. 2016-04-01 16:24:35.722 Time zone: Current: GMT+2, Standard: GMT+1 (Paris, Madrid), DST: GMT+2 (Paris, Madrid (heure d’été)), DST Start: 27/03/2016, DST End: 30/10/2016
. 2016-04-01 16:24:35.722 Login time: vendredi 1 avril 2016 16:24:35
. 2016-04-01 16:24:35.722 --------------------------------------------------------------------------
. 2016-04-01 16:24:35.722 Script: Retrospectively logging previous script records:
> 2016-04-01 16:24:35.722 Script: option batch on
< 2016-04-01 16:24:35.722 Script: batch           on
< 2016-04-01 16:24:35.722 Script: reconnecttime   120
> 2016-04-01 16:24:35.722 Script: option confirm off
< 2016-04-01 16:24:35.722 Script: confirm         off
> 2016-04-01 16:24:35.722 Script: option reconnecttime 120
> 2016-04-01 16:24:35.722 Script: open ftp://xxxxx%40xxxxx.xxxxx-xxxxx.net:***@xxxxx.xxxxx-xxxxx.net:990 -implicit -certificate="xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx" -passive=1 -timeout=15
. 2016-04-01 16:24:35.722 Session name: xxxxx@xxxx.xxxxx-xxxxx.net@xxxxx.xxxxx-xxxxx.net (Ad-Hoc site)
. 2016-04-01 16:24:35.722 Host name: xxxx.xxxxx-xxxxx.net (Port: 990)
. 2016-04-01 16:24:35.722 User name: xxxxx@xxxxx.xxxxx-xxxxx.net (Password: Yes, Key file: No)
. 2016-04-01 16:24:35.722 Transfer Protocol: FTP
. 2016-04-01 16:24:35.722 Ping type: C, Ping interval: 30 sec; Timeout: 15 sec
. 2016-04-01 16:24:35.722 Disable Nagle: No
. 2016-04-01 16:24:35.722 Proxy: none
. 2016-04-01 16:24:35.722 Send buffer: 262144
. 2016-04-01 16:24:35.722 UTF: 2
. 2016-04-01 16:24:35.722 FTP: FTPS: Implicit TLS/SSL; Passive: Yes [Force IP: A]; MLSD: A [List all: A]
. 2016-04-01 16:24:35.722 Session reuse: Yes
. 2016-04-01 16:24:35.722 TLS/SSL versions: TLSv1.0-TLSv1.2
. 2016-04-01 16:24:35.722 Local directory: default, Remote directory: home, Update: Yes, Cache: Yes
. 2016-04-01 16:24:35.722 Cache directory changes: Yes, Permanent: Yes
. 2016-04-01 16:24:35.722 Timezone offset: 0h 0m
. 2016-04-01 16:24:35.836 Connecting to xxxxxx.xxxxx-xxxxx.net:990 ...
. 2016-04-01 16:24:35.907 Connected with xxxxx.xxxxx-xxxxx.net:990, negotiating TLS connection...
. 2016-04-01 16:24:37.262 Verifying certificate for "xxxxx" with fingerprint xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx and 18 failures
. 2016-04-01 16:24:37.271 Certificate for "xxxxxxxxxx" matches configured fingerprint
. 2016-04-01 16:24:37.271 Using TLSv1, cipher TLSv1/SSLv3: AES128-SHA, 1024 bit RSA
. 2016-04-01 16:24:37.272 TLS connection established. Waiting for welcome message...
< 2016-04-01 16:24:37.408 220 xxxx-xxxxxx.net [xxx.xx.xxx.xxwith SSL] - votre IP est xx.xxx.xx.xx
> 2016-04-01 16:24:37.408 USER xxxxx@xxxxx.xxxxx-xxxxx.net
< 2016-04-01 16:24:37.832 331 Mot de passe obligatoire
> 2016-04-01 16:24:37.832 PASS ********
< 2016-04-01 16:24:37.895 230 Bienvenue sur xxxxx.xxxxx-xxxxx.net, xxxxxtest (acces client) - espace libre : 46045 Mo / 51200 Mo
> 2016-04-01 16:24:37.895 SYST
< 2016-04-01 16:24:37.917 215 UNIX Type: L8
> 2016-04-01 16:24:37.917 FEAT
< 2016-04-01 16:24:37.935 211-Extensions supported
< 2016-04-01 16:24:37.935   AUTH TLS
< 2016-04-01 16:24:37.935   PBSZ
< 2016-04-01 16:24:37.935   PROT
< 2016-04-01 16:24:37.935 211 end
> 2016-04-01 16:24:37.935 PBSZ 0
< 2016-04-01 16:24:37.953 200 ok
> 2016-04-01 16:24:37.953 PROT P
< 2016-04-01 16:24:37.971 200 ok
. 2016-04-01 16:24:37.972 Connected
. 2016-04-01 16:24:37.972 --------------------------------------------------------------------------
. 2016-04-01 16:24:37.972 Using FTP protocol.
. 2016-04-01 16:24:37.972 Doing startup conversation with host.
> 2016-04-01 16:24:37.973 PWD
< 2016-04-01 16:24:37.992 257 "/" is current directory
. 2016-04-01 16:24:37.992 Getting current directory name.
. 2016-04-01 16:24:37.992 Startup conversation with host finished.
< 2016-04-01 16:24:37.992 Script: Active session: [1] xxxxx@xxxxx.xxxxx-xxxxx.net@xxxxx.xxxxx-xxxxx.net
> 2016-04-01 16:24:38.151 Script: pwd
< 2016-04-01 16:24:38.152 Script: /
> 2016-04-01 16:24:38.187 Script: checksum -- "" "/IMGP1280.JPG"
< 2016-04-01 16:24:38.187 Script: Operation not supported.
. 2016-04-01 16:24:38.188 Script: Failed
> 2016-04-01 16:24:38.313 Script: exit
. 2016-04-01 16:24:38.313 Script: Exit code: 1
. 2016-04-01 16:24:38.325 Disconnected from server
As you can see in the log, none of the mentioned commands are supported:
