Topic "WinSCP 5.7.7 - Operation not permitted"
trumpy81
GDay All,
I have used WinSCP to access my Synology NAS for some time now and have been very very happy with it. But a recent update to DSM 6.0 has left me with no way to set file/folder permissions in WinSCP, it returns 'Operation not permitted' with the option to abort etc.
With DSM 6.0, and using PuTTY, I must first log in as admin and then issue sudo -s, I am then asked for the password (I use the same PW as for admin) and then I am allowed 'root' access to the NAS.
In DSM 5 and earlier I could simply log in as user 'root' right from the start but this is no longer possible.
Anyhow, the question is, how can I correct this situation with WinSCP so that I can once again set file/folder permissions?
Any help/ideas much appreciated.
Please read documentation:
http://winscp.net/eng/docs/faq_su
If that does not help, come back.
trumpy81
Thanks for the help!
Unfortunately, that didn't help.
I tried to add sudo -s in the SCP/Shell page but that did not work.
I also tried to edit /etc/sudoers but that didn't work either.
At one point while in VI it presented a message telling me that there was a sudoers.swp file.
I'm not Linux savvy enough to understand what that meant though ... lol
"that did not work" won't help us understand what went wrong.
Also you have to understand that you try to break security restrictions of your server. You cannot expect that this will be user-friendly.
trumpy81
OK, when entering sudo -s in SCP/Shell and then trying to login I get a password box appear, I enter my admin password and it returns 'access denied'.
In vi, when I tried to write the file, I got permission denied.
trumpy81
After making a complete mess of things and having to re-install DSM Sad
I was able to successfully do the following:
1. In PuTTY Log on as admin using my admin password.
2. sudo -su root and entered my admin password
3. cd /etc
4. cp sudoers /volume1/Plex (convenient location)
5. cp sudoers sudoers.bak
5. Edit sudoers via WinSCP and edit command
6. Added the following to the sudoers file
7. %administrators ALL=NOPASSWD: ALL, save file
8. cp -f /volume1/Plex/sudoers sudoers
9. Open WinSCP and edited my shortcut
file protocol = scp
host name = IP address
port = configured port number in DSM
user name = admin
password = admin password
Then click on advanced/advanced and for SCP/Shell add sudo -su root
Now I can open WinSCP and have root access to the files which allows me to set file permissions once again ... yay Smile
Thanks to prikryl for supplying the link to the guide that made it all possible, thanks!
PS: I hate vi ... Laughing
