Topic "Batch Script Parameters - Not working"
sundar2013
WinSCP - Version 5.12
Version of Windows - Windows 7
Transfer Protocol - SFTP
Error : Error changing directory to '%1%'.
In Arguments I am passing the below value -script="XXXXXX" -privatekey="XXX.ppk" -parameter="P:\Interface\Backup Files" -log="P:\Interface\winscp.log"
Batch Script :
option batch off
option transfer binary
open sftp:XXXXXXXXXXX -hostkey= XXXXXXXXXXXXXX
cd XXXXXXXX
lcd "%1%"
get *.txt
Error : I am getting an error "Error changing directory to '%1%'". I believe that the batch file doesn't understand the parameter value. "%1%" not taking the value. IF I directly hardcode the path in text file, everything works fine, but I don't want to hard code the server name. Did I use the correct version of Winscp that support parameters?
Please help me.
Thanks.
Sundaramurthy J.
There should be no = after the /parameter
The recommended syntax is:
/parameter // "P:\Interface\Backup Files"
See https://winscp.net/eng/docs/commandline#parameters
sundar2013
Thank you Sir, Now the parameter is working perfectly.
Regards,
Sundaramurthy J.
