Topic "Key authentification with command line"
p1c0
i try to use winscp3 with a script and it work well with user:password@server:port but i want to use key authentification...
Is it possible with command line? How should i proceed? Confused
Thanks a lot in advance.
p1c0
You can create stored session with associated key and open that session.
The next version will allow passing of private key from command line.
I've just try to do this but it doesn't work...
I have generated two key (public and private) with puttygen.exe. I have uploaded the public key on the box where i have the ssh server (openSSH-4.0p1) but when i try to start sshd, it can't read the key...
# /usr/sbin/sshd -h /etc/ssh/public_key -d
debug1: sshd version OpenSSH-4.0p1
debug1: PEM_read_PrivateKey failed
debug1: read PEM private key done : type <unknown>
Could not load host key: /etc/ssh/public_key
Disabling protocol version 1. Could not load host key
Disabling protocol version 2. Could not load host key
sshd: no hostkeys available -- exiting
I suppose that putty keys are not compatible with OpenSSH?!? Is there a solution?? Should i use an other ssh server?
Thanks a lot!
p1c0
Sorry, i have forgotten to log in before post my reply! Confused
-h option is used to set key of the server, not of the user! Key of the user is usually stored into /home/username/.ssh/authorized_keys. You do not need to restart the sshd when you update the user keys.
p1c0
Sorry, i've just found the solution!!
Now i'am searching about how to store a session... I will ask you if i don't find!! Smile
junknav
HI GUys,
Can someone explain clearly how to make key authentication work with an openssh server. I have tried pageant. PuttyGen there was an option to convert the key but pageant doenst take that key.
I am doing something wrong.
Help!
junknav
junknav wrote:
HI GUys,
Help!
SOrry! Figured out the problem. I has copy paste the openssh version 1 key which is displayed on the generate screen. Initially i was trying with key that i got from clicking the save public key button and then realized that my server is less than version 2
