Topic "WinSCP prevents access to files"
eeco4poa
Dear all,
I would like to ask about a behaviour I encounter with WinSCP 5.7.7.
Let's say I create a folder with WinSCP from a distant XP PC (let's name it PC1).
Next, I shut down this first PC1 and I use the Explorer (not WinSCP) in another XP PC (let's name it PC2) to delete/rename this folder. Then I receive the message that it is used by another application, although PC1 is shutted down. In order to do that I have to use again WinSCP from this last PC2.
Is there an explanation for this ?
Thank you all, in advance.
It looks like your SFTP/FTP server on Windows XP "server" is buggy and keeps the folder locked even after the client (WinSCP) disconnects.
Did you actually disconnect WinSCP before shutting down the machine?
I just closed the WinSCP window.
Didn't WinSCP disconnected this way ?
Yes it did.
Apostolos
Ok, I see.
I shall keep an eye on it and I shall let you know.
Tnx a lot.
Apostolos
