Topic "Connect to a Docker container"
Is it possible to connect to a running docker container with Winscp?
I am able to connect to host on which docker system runs. But I cannot find out how to connecting to the docker directly.
Does anyone know what I need to adjust in WinSCP added to connect?
Sure, I am able to open by putty, but I want to connect by WinSCP.
Best Regards
If you are able to connect with PuTTY, I do not see what should prevent you from connecting with WinSCP. Unless you first connect to the host with PuTTY; and then you connect to the docker machine from the host shell.
Show us PuTTY and WinSCP logs for comparison.
Hi prikryl, just want to congratulate you on your answer. This really sorted out the problem. Thank you for you great effort!! Next time, don't reply if you clearly don't have the answer....
