Topic "how to enable sessionlog in powershell example"
istandard
This is the powershell/.NET assembly example I found on this site. What code and where do I add it to enable the session log? Im having another issue with SSH Host fingerprint but I know you will need the log to help.
Here is the example script
try
# Load WinSCP .NET assembly
Add-Type -Path "WinSCPnet.dll"
# Setup session options
HostName = "example.com"
UserName = "user"
Password = "mypassword"
SshHostKeyFingerprint = "ssh-rsa 2048 xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx"
try
# Connect
# Upload files
$transferOptions.TransferMode = [WinSCP.TransferMode]::Binary
$transferResult = $session.PutFiles("d:\toupload\*", "/home/user/", $False, $transferOptions)
# Throw on any error
$transferResult.Check()
# Print results
foreach ($transfer in $transferResult.Transfers)
Write-Host ("Upload of {0} succeeded" -f $transfer.FileName)
finally
# Disconnect, clean up
$session.Dispose()
exit 0
catch [Exception]
Write-Host $_.Exception.Message
exit 1
Set Session.SessionLogPath
See
https://winscp.net/eng/docs/library_session#sessionlogpath
https://winscp.net/eng/docs/logging
