Topic "Access To SessionOptions stucks"
sittiuser1
my problem can be summarised as follows:
- I have 1 server mounting a SFTP server
- I have client A running my VB6 application that utilises WINSCP on Windows XP
- I have client B running the SAME application but on Windows 7
While client A works fine and gets connected to the server in a very short time, client B also works, but it takes a very long time (35 seconds) for just executing the very first access to the SessionOptions structure. Please look at the following code: the time for just executing line 2 is 35 seconds; all other instructions are executed very fast. This only happens on client B.
1 Private mySessionOptions As New SessionOptions
2 With mySessionOptions
3 .Protocol = Protocol_Sftp
4 .HostName = strhostname
5 .username = strusername
6 .password = strPassword
7 .SshHostKeyFingerprint = strfingerprint
8 End With
Further information:
- Client B is fully dedicated to my only application.
- No firewall active neither on client nor on server machines.
- No antivirus active neither on client nor on server machines.
Can somebody give a hint?
Many thanks.
Roberto Weger
Italy
It is hardly about firewall as no network connection occurs when creating SessionOptions.
It's likely the assembly loading that takes time.
Try to debug it using Fuslogvw.exe:
https://msdn.microsoft.com/en-us/library/e74a18c4.aspx
sittiuser1
Thanks. However, although it takes so much time, after the loading of SessionOptions, all works fine. So, it doesn't look like being a problem related to failure of assembly loading, in the sense that the loading works, but it take ages.
Besides that, I don't have FUSLOGVW.EXE on my PC, nor I found where to download it from.
Can you please help me?
Roberto
It's part of Windows SDK.
Or follow these instructions to get the log without the Fuslogvw:
http://stackoverflow.com/a/28997232/850848
The SessionOptions constructor looks like this:
public SessionOptions()
    Timeout = new TimeSpan(0, 0, 15);
    RawSettings = new Dictionary<string,string>();
So the contructor itself cannot be the problem.
