Synchronize -> Can't create file error
siulogoid
Portugal
I'm doing some backups from several machines.
1 of the machines are getting the same error everytime always in same file.
It starts to sync but stops in this file.
Can you understand why?
. 2016-04-11 16:54:00.075 --------------------------------------------------------------------------
. 2016-04-11 16:54:00.075 WinSCP Version 5.7.7 (Build 6257) (OS 6.3.9600 - Windows Server 2012 R2 Standard)
. 2016-04-11 16:55:45.059 Starting upload of E:\Backups\DAILY_11042016_165356\DriveC\...\rabbit_federation_exchange_link_sup_sup.beam
> 2016-04-11 16:55:45.059 TYPE I
< 2016-04-11 16:55:45.153 200 Type set to I.
> 2016-04-11 16:55:45.153 PASV
< 2016-04-11 16:55:45.262 227 Entering Passive Mode (213,30,8,197,234,255)
> 2016-04-11 16:55:45.262 STOR rabbit_federation_exchange_link_sup_sup.beam
< 2016-04-11 16:55:45.356 451 Can't create file "rabbit_federation_exchange_link_sup_sup.beam".
. 2016-04-11 16:55:45.356 Copying files to remote side failed.
* 2016-04-11 16:55:45.356 (ExtException) **Copying files to remote side failed.**
* 2016-04-11 16:55:45.356 Can't create file "rabbit_federation_exchange_link_sup_sup.beam".
. 2016-04-11 16:55:45.356 Asking user:
. 2016-04-11 16:55:45.356 Error transferring file 'E:\Backups\DAILY_11042016_165356\...\rabbit_federation_exchange_link_sup_sup.beam'. ("Copying files to remote side failed.","Can't create file ""rabbit_federation_exchange_link_sup_sup.beam"".")
< 2016-04-11 16:55:45.356 Script: Error transferring file 'E:\Backups\DAILY_11042016_165356\...\rabbit_federation_exchange_link_sup_sup.beam'.
< 2016-04-11 16:55:45.356 Script: Copying files to remote side failed.
< 2016-04-11 16:55:45.356 Can't create file "rabbit_federation_exchange_link_sup_sup.beam".
* 2016-04-11 16:55:45.356 (EScpSkipFile) Error transferring file 'E:\Backups\DAILY_11042016_165356\...\rabbit_federation_exchange_link_sup_sup.beam'.
* 2016-04-11 16:55:45.356 Copying files to remote side failed.
. 2016-04-11 16:55:45.356 Script: Failed
. 2016-04-11 16:55:45.356 Script: Exit code: 1
. 2016-04-11 16:55:45.356 Disconnected from server
siulogoid
Portugal
Re: Synchronize -> Can't create file error
I guess it was related with long paths+filename.
