Topic "WinSCP 557 installation"
node
I am using Ubuntu 15.10/64bit, I install "WINE" which allow me to run Windows program in Linux. I installed WinSCP 557, however, when I start it, I am getting some of the TABs "blacked out" and when I attempt to type the address in the address bar the cursor is moving but not seeing any text written.
The TABS that are "blacked out" at the Session / Save / Advance / Login
Really been racking my head on this. Any help would be appreciated. Thanks
node
Can you attach a screenshot?
Did you consider reporting it to a Wine project instead?
node
I got it to worked, I first deleted the 553 version that was giving the black out TABs, and downloaded 557 version. I keep getting this error on the screen shot posted. I selected "ignore" and WinSCP installed and opened.
I have tested it and it worked fine.
I read however others getting this missing dll error. Hope I do not require this missing file, because no where I saw how to solve it.
node
Screenshot from 2016-04-16 01-56-57.png (288.71 KB) [Download]
Description: (none)
