Topic "SSL3 alert write issue after 5.7.7 upgrade"
itservices
Since upgrading to version 5.7.7 we are experiencing the following error message when connecting to an FTP site using TLS/SSL Explicit encryption:
SSL3 alert write: fatal: handshake failure
TLS connect: error in error
Can't establish TLS connection
Disconnected from server
Connection failed.
Is there a setting that we need to change in the WinSCP client software that will allow us to connect successfully?
What version were you using previously? Since version 5.6.2, WinSCP does not allow SSL 3.0 protocol by default.
You have to enable it in session settings:
https://winscp.net/eng/docs/ui_login_tls
itservices
I am not sure specifically which version we were previously using however most likely it was a version prior to 5.6.2. Which setting do I need to change on your link to allow SSL3? Maximum TLS/SSL version?
Minimum TLS/SSL version.
itservices
Thanks. Unfortunately changing the minimum TLS/SSL version to SSL3 did not resolve the issue. What's weird is that if we use Filezilla to connect we do not have the issue using the same settings.
What cipher does FileZilla use against your server?
Can you try to connect using WinSCP 5.7.6? If it works, please attach a session log file.
Possibly the same issue as here:
https://winscp.net/forum/viewtopic.php?t=22968
