Topic "overwrite read-only files"
no matter
Which option/switch will force WinSCP overwrite without prompts local NTFS/FAT files, having "Read-Only" attribute?
P.S.
Do not push me to "Documentation", if you do not want to answer the question.
There's no such option in GUI.
If you mean scripting, use batch confirm off (what is the default for scripts).
Martin,
Many thanks for your response. I am using scripting in this task, have "batch confirm" turned "off" and it works as expected, until someone put "Read-Only" file into folder, involved in synchronization. "PreserveReadOnly" is not applicable there, because local folder receiving files from remote can be updated directly by local users with files already have "Read-Only" attribute. Now I run script to remove "Read-Only" attributes before running WinSCP script. This resolves the issue but folders tree is huge and re-setting attributes take time. I went through documentation but did not find option/switch can be used to resolve the issue by WinSCP itself. If such option/switch exists, please point me to right place in documentation.
Regards,
Mark
prikryl wrote:
Martin,
Sure, see attached. The log produced after setting Read-Only attribute to ".banner" file.
C:\tmp\1>attrib C:\tmp\2\.banner
A R C:\tmp\2\.banner
Regards,
Mark
winscp_overwrite_local_readonly_failed.7z (3.11 KB) Private file
Description: unable to overwrite read-only file log
OK, I've assumed that by "prompt" you mean a confirmation prompt, that WinSCP displays with SFTP protocol, before overwriting a read-only file.
But you obviously mean an error message that you get with FTP. As with FTP protocol, overwriting read-only files is not implemented.
So there's no way currently, sorry.
prikryl wrote:
... not implemented ...
Thank you for your response. This is what I wanted to be sure.
