Topic "SyncrhonizeDirectories.Removals"
calatubo
Hello, I'm using this piece of code
Dim synchronizationResult As SynchronizationResult
synchronizationResult = MySession.SynchronizeDirectories(SynchronizationMode.Remote, local, remote, True, True)
For n = 0 To synchronizationResult.Removals.Count - 1
l.WriteLine("Rimosso " + synchronizationResult.Removals(n).FileName)
Next
For n = 0 To synchronizationResult.Failures.Count - 1
l.WriteLine("Errore " + synchronizationResult.Failures(n).Message)
Next
My intention is to log the files that were been removed due exists in remote and not in local. The list contains the files removed and everything is ok.
If I made the reverse synchronization (SynchronizationMode.Local) the files removed in local due are not present in remote, are not listed in .Removals list. The list is empty every time.
Am I mistake something or is there another metodh to retrive the removed files in this case?
Thanks.
There's no way to list local removed files.
user2016
IS there any reason why locally removed files could not be listed?
Well, it's just not implemented yet.
user2016
Are there any plans when this will be available?
I'll consider adding it.
But you can implement it as easily as:
string[] before = Directory.EnumerateFileSystemEntries(localPath, "*", SearchOption.AllDirectories).ToArray();
session.SynchronizeDirectories(...);
string[] after = Directory.EnumerateFileSystemEntries(localPath, "*", SearchOption.AllDirectories).ToArray();
IEnumerable<string> removals = before.Except(after);
calatubo
Wow, that's great! Thanks.
