Topic "simple script does not work"
Michael_ger
Hi
I am just beginning to work with winscp
My Problem:
Example given:
winscp.com /script=myscript.txt
myscript.txt
open ftp://user:password@example.com/
myScript 1):
open ftp://b*******.de
password@b*******.de/
myscript 2):
open ftp://user:password@b*******.de/
myscript 3):
open ftp://password@b*******.de/
No scripot works.
The server asks my password, but I want do run the script without any interuption
Perhaps you can help me?
The open ftp://user:password@b*******.de/ is correct.
danpino
ERROR
Access denied.
Authentication failed.
This is the script:
open ftp://iesanvic:PASSWORD@www.sanvicente.edu.co/
mput "C:\Colegio\wlistas\SNP\*.pdf" "/httpdocs/portal/wlistas/snp/"
any help?
Thanks Very Much !!
Don't you have some special character in the password?
https://winscp.net/eng/docs/session_url#special
You can also try to enable password logging with /loglevel=* to see if a correct password is used.
