Topic "Winscp loosing a saved session details"
Graham_jones@...
Hi
I have a session saved, host, username and password, which I then use via,
the pc scheduler and a powershell script to upload and download data,
every hour throughout the day.
This works fine but, after a few days the session is dropped from winscp,
winscp login screen just shows the create the New site option,
and I have to re-import the session details from a saved configuration file,
or manually re-enter.
I have tried various versions from 5.5.3 up to 5.7.7,
and they all do the same thing.
it is running on a Windows 7 service pack 1 PC
Any suggestions would be appreciated
Do you keep WinSCP settings in registry (the default) or in an INI file?
What kind of machine is that? Is it a regular desktop or some server?
I have this bug too... my settings are in an INI file, Windows 7 with last update, Desktop PC.
Have you solution? Thanks!
Can you provide us more details? When is it happening? (How often?)
