Topic "Synchronize Directories always uploads all files with .NET Using Timestamp mode."
glavian
I'm using the .NET Library and anytime I call SynchronizeDirectories using TimeStampMode it synchronizes the whole directory. I'm only doing remote synchronization. If I use the WINSCP client I do not experience this issue so I'm not sure if I'm missing some setting with .NET or there is a bug. I am using CoreFTP as my server. I also did a test where I grab the fileinfo myself using the .NET and it appears to return the same LastWriteTime stamp as my local file.
This is the code I'm using to do the sync:
            TransferOptions transferOptions = new TransferOptions();
               transferOptions.TransferMode = TransferMode.Binary;
               transferOptions.FileMask = WinSCPUtil.CreateFilterMask(m_mapping);
               var syncResult = session.SynchronizeDirectories(SynchronizationMode.Remote, m_mapping.SourcePath, m_mapping.DestPath, false, false, SynchronizationCriteria.Time, transferOptions);
               syncResult.Check();
Any help would be appreciated. I'd prefer to use SynchronizeDirectories over writing my own function that does this.
Please attach a full session log file showing the problem, both for GUI and the .NET assembly.
glavian
I have attached the log file. The test case I did was as follows.
1) I cleaned out my coreFTP server directory.
2) Ran File Synchronization. All expected files were updated.
3) Added a new file into the directory.
4) All files were again updated even though "time" is my sync mode.
Based on what I can tell it looks like the "Ms" value on the file time-stamps aren't being retrieved when listing the remote directory.
WinSCP.log (41.76 KB) Private file
Description: (none)
It's the filemask that breaks it. Using an absolute include mask in synchronization just does not work, because it effectively treats all files on the opposite side as non-existing. What did you try to achieve by the D:\bin\*.* mask? Did you want to exclude subfolders? For that use | */.
