Topic "ExeSessionProcess.GetExecutablePath() doesn't search in 'Program Files (x86)' directory"
tattdogg
Hi
Possible fix: https://github.com/mirror/winscp/pull/1/commits/0996f04cda7ca0d90febce16e0f3da986709d820
Also you can add search in %PATH% variable:
Environment.GetEnvironmentVariable("PATH")?.Split(';').SingleOrDefault(x => x.EndsWith("\\WinSCP\\"));
tattdogg
Thanks for spotting this.
The ProgramFilesX86 requires .NET 4, so I cannot use it.
Also what primarily needs fixing, is the GetInstallationPath implementation.
Anyway, both are fixed:
https://winscp.net/tracker/show_bug.cgi?id=1421
Though note that you generally should not rely on WinSCP.exe in "Program Files". You should distribute the executable with your .NET application.
https://winscp.net/eng/docs/library_install
The lookup in "Program Files" is really only the last resort fallback.
tattdogg
Thank you
