Topic "Unespected directory listing line error"
glcp
I'm triyng to log in to a network device using scp protocol, but I got this error:
" Unespected directory listing line" (see image below)
http://i.imgur.com/6UHEvG8.png
I have no problem logging in with Putty.
Any help would be much appreciated.
The directory listing of your device is not compatible with WinSCP.
Try using SFTP instead of SCP.
glcp
Sftp is not supported in this device.
It's not possible to customize the directory listing so that WinScp can show file system contents ?
No.
All you can try to do is to alias the ls command to produce an output in format of the standard *nix ls.
