Topic "setuid,setgid,sticky not working in 5.7.7 ?"
nova
it appears that if I right click on a unix file or directory and try to set uid,gid,sticky bit that it doesn't take, if I hit refresh it also doesn't take.. I can make the changes on my rhel 5 Linux machine and it shows on winscp screen but I cant set from winscp.
Has anyone seen this behavior?
more detail:
using the GUI, tried to change permissions on files and directories in unix window - setting the suid, sgid & sticky bit , none would take effect. When doing on the unix system itself, the changes show in Winscp.
This worked prior on Winscp 5.1.7
Can you attach a session log file from both versions?
nova
attached is log
winscp.logat577.txt (17.23 KB) Private file
Description: log at 5.7.7 version
nova
sorry only version I have access to is this latest one
Sorry, I've forgot to mention that I need a log on Debug 2-level:
https://winscp.net/eng/docs/ui_pref_logging
nova
here is a new log at debug2 level
debug.log (718.15 KB) [Download]
Description: (none)
Thanks for the log.
Nothing wrong on WinSCP side though.
You are using an ancient (2008) version 4.3 of the OpenSSH server, that does not support the setuid, setgid and sticky permissions.
