Topic "Abort script if local file exists"
Gazz
Hi I need to check if a file exists on the remote server and abort the script if NOT. I am using option "failonnomatch on" which works fine for the remote directory, but I also need to abort the script if the file DOES exist in the local directory. I tried option "failonnomatch off" for the local file but it does not appear to work that way, I was hoping it would just be the opposite to 'on' if the condition was met. Is there a simple option to abort the script if a local file already exists i.e. local file (C:\ssis\triggers\*.TRG) simple example of what I have so far (very basic) below.
This Works
open sftp://sftptcu:**************@10.253.***.**
cd /data/udaftp/cl-universe/u3/TCU/DEX.TRIGGER
option failonnomatch on
ls /data/udaftp/cl-universe/u3/TCU/DEX.TRIGGER/*.TRG
This Doesn't
lcd C:\SSIS\AML\SourceFiles\
option failonnomatch off
lls C:\SSIS\AML\SourceFiles\*.TRG
Thanks Gazz
Just don't start the script in the first place.
See
https://winscp.net/eng/docs/guide_automation_conditional#scripting
https://winscp.net/eng/docs/script_checking_file_existence#local
Gazz
Yes I created a batch file to check the local directories and if file is not there it calls my WinSCP batch which contains the 'failonnomatch' option. That works well enough.
One issue I did have is in the script below. I set the delete option for both .TRG files but it seems they were both deleted after the 'first' file transfers, causing the second .TRG to fail. Also any further sessions in the script fail after the second .TRG is not found. Can I force the script to keep running or is it better to just delete the two .TRG files as single session at the end of the entire script?
cd /udaftp/cl-universe/u3/TCU/DEX.TRIGGER
option transfer ascii
get -delete TCU.AML.TRG C:\SSIS\AML\SourceFiles\
close
get -delete TCU.RPD.TRG C:\SSIS\RPD\SourceFiles\
close
cd /udaftp/DEX.EXTRACTDIR.RPD/TCU
get *.* -filemask="* | ACCTRAN; EVENTHISTORY" C:\SSIS\RPD\SourceFiles\
close
Thanks Gazz.
Sorry, I do not understand the problem.
