Topic "SshPrivateKeyPassphrase and ConvertTo-SecureString"
edware
When using
with a text based passphrase the powershell script works fine.
If i try to use it with:
$sessionOptions.SshPrivateKeyPassphrase = ConvertTo-SecureString
I get an error:
Connection has been unexpectedly closed. Server sent command exit status 0.
edware
Found a workaround:
$sessionOptions.SecurePassword = ConvertTo-SecureString
$sessionOptions.SshPrivateKeyPassphrase = $sessionOptions.SecurePassword
And this works.
edware wrote:
Found a workaround:
And this works.
Now when testing on another system it is not working.
The SecureString is supported for password only, not for passphrase.
You have to decrypt the secure string yourself.
See http://stackoverflow.com/q/28352141/850848
