Topic "but error occurred while setting the permissions and/or timestamp"
matta25
I am getting the warning message "**Upload of file '...' was successful, but error occurred while setting the permissions and/or timestamp.**
If the problem persists, turn off setting permissions or preserving timestamp. Alternatively you can turn on 'Ignore permission errors' option.
Error code: 3
Error message from server: This server does not support operations to modify file attributes.")
I am trying to do this in my vb.net code Yet the third like it does not like the NULL. Any Ideas on how to correct this?
transferOptions.TransferMode = TransferMode.Automatic
transferOptions.FilePermissions = Null
transferOptions.PreserveTimestamp = False
Matt
Do you mean "third line"?
What does it mean "does not like the NULL"?
And you do not have to set the FilePermissions to NULL, it's the default value anyway.
matta25
I fond this in another post transferOptions.FilePermissions = Nothing I did not get an error in VB like I did for NULL and in my FTP log it shows:
put -nopermissions -nopreservetime -transfer="automatic" -- "C:\test\test.txt" "/"
No error.
Matt
Yes, indeed it's Nothing in VB.NET, not Null.
Though again, you do not have to set the FilePermissions to Nothing as that's the default value.
