Topic "Can not get the directory listing"
juanpotts56
below is the log for the session. the connection should be Active. for some reason it looks like it does everything except the listing
. 2016-05-12 16:50:55.258 --------------------------------------------------------------------------
. 2016-05-12 16:50:55.259 WinSCP Version 4.3.7 (Build 1679) (OS 6.1.7601 Service Pack 1)
. 2016-05-12 16:50:55.259 Configuration: HKEY_CURRENT_USER\Software\Martin Prikryl\WinSCP 2\
. 2016-05-12 16:50:55.261 Local account: COV\aajuan.potts
. 2016-05-12 16:50:55.261 Login time: Thursday, May 12, 2016 4:50:55 PM
. 2016-05-12 16:50:55.261 --------------------------------------------------------------------------
. 2016-05-12 16:50:55.261 Session name: FetchFTP@10.192.120.10 (Stored session)
. 2016-05-12 16:50:55.262 Host name: 10.192.120.10 (Port: 22)
. 2016-05-12 16:50:55.262 User name: FetchFTP (Password: No, Key file: No)
. 2016-05-12 16:50:55.262 Tunnel: No
. 2016-05-12 16:50:55.262 Transfer Protocol: FTP
. 2016-05-12 16:50:55.262 Ping type: C, Ping interval: 30 sec; Timeout: 15 sec
. 2016-05-12 16:50:55.262 Proxy: none
. 2016-05-12 16:50:55.262 FTP: FTPS: Explicit TLS; Passive: No [Force IP: No]
. 2016-05-12 16:50:55.262 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2016-05-12 16:50:55.262 Cache directory changes: Yes, Permanent: Yes
. 2016-05-12 16:50:55.262 DST mode: 1
. 2016-05-12 16:50:55.262 --------------------------------------------------------------------------
. 2016-05-12 16:50:55.263 Password prompt (no password provided or last login attempt failed)
. 2016-05-12 16:51:05.635 Connecting to 10.192.120.10:22 ...
. 2016-05-12 16:51:05.640 Connected with 10.192.120.10:22, negotiating SSL connection...
< 2016-05-12 16:51:05.641 220 Microsoft FTP Service
> 2016-05-12 16:51:05.641 AUTH TLS
< 2016-05-12 16:51:05.641 234 AUTH command ok. Expecting TLS Negotiation.
. 2016-05-12 16:51:05.939 SSL connection established. Waiting for welcome message...
> 2016-05-12 16:51:05.939 USER FetchFTP
< 2016-05-12 16:51:05.939 331 Password required for FetchFTP.
> 2016-05-12 16:51:05.939 PASS *********
< 2016-05-12 16:51:05.939 230 User logged in.
> 2016-05-12 16:51:05.940 SYST
< 2016-05-12 16:51:05.940 215 Windows_NT
> 2016-05-12 16:51:05.940 FEAT
< 2016-05-12 16:51:05.941 211-Extended features supported:
< 2016-05-12 16:51:05.942 LANG EN*
< 2016-05-12 16:51:05.942 UTF8
< 2016-05-12 16:51:05.942 AUTH TLS;TLS-C;SSL;TLS-P;
< 2016-05-12 16:51:05.942 PBSZ
< 2016-05-12 16:51:05.942 PROT C;P;
< 2016-05-12 16:51:05.942 CCC
< 2016-05-12 16:51:05.942 HOST
< 2016-05-12 16:51:05.942 SIZE
< 2016-05-12 16:51:05.942 MDTM
< 2016-05-12 16:51:05.942 REST STREAM
< 2016-05-12 16:51:05.942 211 END
> 2016-05-12 16:51:05.943 OPTS UTF8 ON
< 2016-05-12 16:51:05.943 200 OPTS UTF8 command successful - UTF8 encoding now ON.
> 2016-05-12 16:51:05.943 PBSZ 0
< 2016-05-12 16:51:05.944 200 PBSZ command successful.
> 2016-05-12 16:51:05.944 PROT P
< 2016-05-12 16:51:05.945 200 PROT command successful.
. 2016-05-12 16:51:05.947 Connected
. 2016-05-12 16:51:05.948 --------------------------------------------------------------------------
. 2016-05-12 16:51:05.948 Using FTP protocol.
. 2016-05-12 16:51:05.948 Doing startup conversation with host.
> 2016-05-12 16:51:05.951 PWD
< 2016-05-12 16:51:05.952 257 "/" is current directory.
. 2016-05-12 16:51:05.956 Getting current directory name.
. 2016-05-12 16:51:05.960 Retrieving directory listing...
> 2016-05-12 16:51:05.961 TYPE A
< 2016-05-12 16:51:05.961 200 Type set to A.
> 2016-05-12 16:51:05.961 PORT 10,193,21,210,244,169
< 2016-05-12 16:51:05.961 200 PORT command successful.
> 2016-05-12 16:51:05.961 LIST -a
< 2016-05-12 16:51:05.961 150 Opening ASCII mode data connection.
. 2016-05-12 16:51:20.605 Timeout detected.
. 2016-05-12 16:51:20.605 Could not retrieve directory listing
. 2016-05-12 16:51:20.606 Connection was lost, asking what to do.
. 2016-05-12 16:51:20.606 Asking user:
. 2016-05-12 16:51:20.606 Lost connection. ("Timeout detected.","Could not retrieve directory listing","Opening ASCII mode data connection.")
. 2016-05-12 16:51:25.677 Password prompt (no password provided or last login attempt failed)
. 2016-05-12 16:51:37.643 Connection was lost, asking what to do.
. 2016-05-12 16:51:37.643 Asking user:
. 2016-05-12 16:51:37.643 Authentication failed. ()
. 2016-05-12 16:51:42.712 Password prompt (no password provided or last login attempt failed)
. 2016-05-12 16:51:54.382 Connecting to 10.192.120.10:22 ...
. 2016-05-12 16:51:54.387 Connected with 10.192.120.10:22, negotiating SSL connection...
< 2016-05-12 16:51:54.387 220 Microsoft FTP Service
> 2016-05-12 16:51:54.387 AUTH TLS
< 2016-05-12 16:51:54.387 234 AUTH command ok. Expecting TLS Negotiation.
. 2016-05-12 16:51:54.399 SSL connection established. Waiting for welcome message...
> 2016-05-12 16:51:54.399 USER FetchFTP
< 2016-05-12 16:51:54.400 331 Password required for FetchFTP.
> 2016-05-12 16:51:54.400 PASS *********
< 2016-05-12 16:51:54.400 230 User logged in.
> 2016-05-12 16:51:54.400 SYST
< 2016-05-12 16:51:54.400 215 Windows_NT
> 2016-05-12 16:51:54.401 FEAT
< 2016-05-12 16:51:54.401 211-Extended features supported:
< 2016-05-12 16:51:54.401 LANG EN*
< 2016-05-12 16:51:54.401 UTF8
< 2016-05-12 16:51:54.402 AUTH TLS;TLS-C;SSL;TLS-P;
< 2016-05-12 16:51:54.402 PBSZ
< 2016-05-12 16:51:54.402 PROT C;P;
< 2016-05-12 16:51:54.402 CCC
< 2016-05-12 16:51:54.402 HOST
< 2016-05-12 16:51:54.402 SIZE
< 2016-05-12 16:51:54.402 MDTM
< 2016-05-12 16:51:54.402 REST STREAM
< 2016-05-12 16:51:54.402 211 END
> 2016-05-12 16:51:54.402 OPTS UTF8 ON
< 2016-05-12 16:51:54.403 200 OPTS UTF8 command successful - UTF8 encoding now ON.
> 2016-05-12 16:51:54.403 PBSZ 0
< 2016-05-12 16:51:54.404 200 PBSZ command successful.
> 2016-05-12 16:51:54.404 PROT P
< 2016-05-12 16:51:54.405 200 PROT command successful.
. 2016-05-12 16:51:54.408 Connected
. 2016-05-12 16:51:54.408 Doing startup conversation with host.
> 2016-05-12 16:51:54.411 PWD
< 2016-05-12 16:51:54.412 257 "/" is current directory.
. 2016-05-12 16:51:54.415 Getting current directory name.
. 2016-05-12 16:51:54.415 Startup conversation with host finished.
. 2016-05-12 16:51:54.425 Retrieving directory listing...
> 2016-05-12 16:51:54.425 TYPE A
< 2016-05-12 16:51:54.426 200 Type set to A.
> 2016-05-12 16:51:54.427 PORT 10,193,21,210,244,175
< 2016-05-12 16:51:54.428 200 PORT command successful.
> 2016-05-12 16:51:54.428 LIST
< 2016-05-12 16:51:54.430 150 Opening ASCII mode data connection.
. 2016-05-12 16:52:09.275 Timeout detected.
. 2016-05-12 16:52:09.275 Could not retrieve directory listing
* 2016-05-12 16:52:09.276 (ESshFatal) Lost connection.
* 2016-05-12 16:52:09.276 Timeout detected.
* 2016-05-12 16:52:09.276 Could not retrieve directory listing
* 2016-05-12 16:52:09.276 Opening ASCII mode data connection.
* 2016-05-12 16:52:09.276 Error listing directory '/'.
. 2016-05-12 16:52:14.348 Password prompt (no password provided or last login attempt failed)
* 2016-05-12 16:52:21.261 (ESshFatal) Authentication failed.
Why do you use the active mode? Did you try the passive?
To learn why, see https://winscp.net/eng/docs/ftp_modes
Also make sure you use the latest version of WinSCP.
