Topic "Unexpected directory listing line 'root@dom:/# total 88"
mnegg
Hello
I Keep getting this error - Unexpected directory listing line 'root@dom:/# total 88'. -. I can connect from putty.
I´m trying to connect from a W7 to a Ubuntu 14.04 X86 64 Minimal
I´m not a Linux heavy user, sorry if I´m missing something silly... I already check to see if ls output is ok, and it seems to be.
Here is what I get from a ls -la command:
root@dom:/# ls -la
total 88
drwxr-xr-x 23 root root 4096 May 5 17:38 .
drwxr-xr-x 23 root root 4096 May 5 17:38 ..
drwx------ 2 root root 4096 May 5 17:02 .cpt_hardlink_dir_a920e4ddc233afddc9fb53d26c392319
drwxr-xr-x 2 root root 4096 Jan 8 2015 bin
drwxr-xr-x 2 root root 4096 Jan 8 2015 boot
drwxr-xr-x 6 root 500 740 May 11 17:11 dev
drwxr-xr-x 57 root root 4096 May 11 17:11 etc
-rw-r--r-- 1 root root 0 Jan 8 2015 fastboot
drwxr-xr-x 2 root root 4096 Jan 8 2015 home
drwxr-xr-x 13 root root 4096 May 5 17:02 lib
drwxr-xr-x 2 root root 4096 Jan 8 2015 lib64
drwx------ 2 root root 16384 Jan 8 2015 lost+found
drwxr-xr-x 2 root root 4096 Jan 8 2015 media
drwxr-xr-x 2 root root 4096 Jan 8 2015 mnt
drwxr-xr-x 2 root root 4096 Jan 8 2015 opt
dr-xr-xr-x 27 root root 0 May 11 17:11 proc
drwx------ 4 root root 4096 May 5 17:53 root
drwxr-xr-x 11 root root 380 May 11 17:11 run
drwxr-xr-x 2 root root 4096 Jan 8 2015 sbin
drwxr-xr-x 2 root root 4096 Jan 8 2015 srv
drwxr-xr-x 7 root root 0 May 11 17:11 sys
drwxrwxrwt 2 root root 4096 May 11 17:11 tmp
drwxr-xr-x 10 root root 4096 Jan 8 2015 usr
drwxr-xr-x 11 root root 4096 Jan 8 2015 var
Here is the connection log:
. 2016-05-16 19:38:59.786 --------------------------------------------------------------------------
. 2016-05-16 19:38:59.786 WinSCP Version 5.7.7 (Build 6257) (OS 6.1.7601 Service Pack 1 - Windows 7 Ultimate)
. 2016-05-16 19:38:59.787 Configuration: HKCU\Software\Martin Prikryl\WinSCP 2\
. 2016-05-16 19:38:59.787 Log level: Debug 2
. 2016-05-16 19:38:59.787 Local account: cand\cand
. 2016-05-16 19:38:59.787 Working directory: C:\Program Files\WinSCP
. 2016-05-16 19:38:59.787 Process ID: 2748
. 2016-05-16 19:38:59.787 Command-line: "C:\Program Files\WinSCP\WinSCP.exe"
. 2016-05-16 19:38:59.787 Time zone: Current: GMT-3, Standard: GMT-3 (Hora oficial do Brasil), DST: GMT-2 (Horário brasileiro de verão), DST Start: 15/10/2016, DST End: 20/02/2016
. 2016-05-16 19:38:59.787 Login time: segunda-feira, 16 de maio de 2016 19:38:59
. 2016-05-16 19:38:59.787 --------------------------------------------------------------------------
. 2016-05-16 19:38:59.787 Session name: super (Site)
. 2016-05-16 19:38:59.787 Host name: 26.108.43.2 (Port: 22)
. 2016-05-16 19:38:59.787 User name: console-Z2MPld (Password: Yes, Key file: No)
. 2016-05-16 19:38:59.787 Tunnel: Yes
. 2016-05-16 19:38:59.787 Tunnel: Host name: 26.108.43.2 (Port: 22)
. 2016-05-16 19:38:59.787 Tunnel: User name: console-Z2MPld (Password: Yes, Key file: Yes)
. 2016-05-16 19:38:59.787 Tunnel: Local port number: 0
. 2016-05-16 19:38:59.787 Transfer Protocol: SCP
. 2016-05-16 19:38:59.787 Ping type: N, Ping interval: 30 sec; Timeout: 15 sec
. 2016-05-16 19:38:59.787 Disable Nagle: No
. 2016-05-16 19:38:59.787 Proxy: none
. 2016-05-16 19:38:59.787 Send buffer: 262144
. 2016-05-16 19:38:59.787 SSH protocol version: 2; Compression: Yes
. 2016-05-16 19:38:59.787 Bypass authentication: No
. 2016-05-16 19:38:59.788 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2016-05-16 19:38:59.788 Ciphers: aes,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2016-05-16 19:38:59.788 KEX: dh-gex-sha1,dh-group14-sha1,dh-group1-sha1,rsa,WARN
. 2016-05-16 19:38:59.788 SSH Bugs: A,A,A,A,A,A,A,A,A,A,A,A
. 2016-05-16 19:38:59.788 Simple channel: Yes
. 2016-05-16 19:38:59.788 Return code variable: ?; Lookup user groups: A
. 2016-05-16 19:38:59.788 Shell: sudo su -
. 2016-05-16 19:38:59.788 EOL: 0, UTF: 2
. 2016-05-16 19:38:59.788 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: No
. 2016-05-16 19:38:59.788 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: Yes
. 2016-05-16 19:38:59.788 Local directory: C:\Users\candida\Documents, Remote directory: /, Update: No, Cache: Yes
. 2016-05-16 19:38:59.788 Cache directory changes: Yes, Permanent: Yes
. 2016-05-16 19:38:59.788 DST mode: 1;Timezone offset: 0h 0m
. 2016-05-16 19:38:59.788 --------------------------------------------------------------------------
. 2016-05-16 19:38:59.848 Opening tunnel.
. 2016-05-16 19:38:59.850 Autoselected tunnel local port number 50000
. 2016-05-16 19:38:59.903 [Tunnel] Looking up host "26.108.43.2"
. 2016-05-16 19:38:59.903 [Tunnel] Connecting to 26.108.43.2 port 22
. 2016-05-16 19:39:00.128 [Tunnel] Selecting events 63 for socket 932
. 2016-05-16 19:39:00.162 [Tunnel] Waiting for the server to continue with the initialization
. 2016-05-16 19:39:00.162 [Tunnel] Looking for incoming data
. 2016-05-16 19:39:00.162 [Tunnel] Looking for network events
. 2016-05-16 19:39:00.162 [Tunnel] Detected network event
. 2016-05-16 19:39:00.162 [Tunnel] Enumerating network events for socket 932
. 2016-05-16 19:39:00.162 [Tunnel] Enumerated 18 network events making 18 cumulative events for socket 932
. 2016-05-16 19:39:00.162 [Tunnel] Handling network write event on socket 932 with error 0
. 2016-05-16 19:39:00.162 [Tunnel] Handling network connect event on socket 932 with error 0
. 2016-05-16 19:39:00.357 [Tunnel] Detected network event
. 2016-05-16 19:39:00.357 [Tunnel] Enumerating network events for socket 932
. 2016-05-16 19:39:00.357 [Tunnel] Enumerated 1 network events making 1 cumulative events for socket 932
. 2016-05-16 19:39:00.357 [Tunnel] Handling network read event on socket 932 with error 0
. 2016-05-16 19:39:00.357 [Tunnel] Server version: SSH-2.0-OpenSSH_5.3
. 2016-05-16 19:39:00.357 [Tunnel] Using SSH protocol version 2
. 2016-05-16 19:39:00.357 [Tunnel] We claim version: SSH-2.0-WinSCP_release_5.7.7
. 2016-05-16 19:39:00.357 [Tunnel] Waiting for the server to continue with the initialization
. 2016-05-16 19:39:00.357 [Tunnel] Looking for incoming data
. 2016-05-16 19:39:00.357 [Tunnel] Looking for network events
. 2016-05-16 19:39:00.580 [Tunnel] Detected network event
. 2016-05-16 19:39:00.580 [Tunnel] Enumerating network events for socket 932
. 2016-05-16 19:39:00.580 [Tunnel] Enumerated 1 network events making 1 cumulative events for socket 932
. 2016-05-16 19:39:00.580 [Tunnel] Handling network read event on socket 932 with error 0
. 2016-05-16 19:39:00.580 [Tunnel] Doing Diffie-Hellman group exchange
. 2016-05-16 19:39:00.580 [Tunnel] Waiting for the server to continue with the initialization
. 2016-05-16 19:39:00.580 [Tunnel] Looking for incoming data
. 2016-05-16 19:39:00.580 [Tunnel] Looking for network events
. 2016-05-16 19:39:01.092 [Tunnel] Detected network event
. 2016-05-16 19:39:01.092 [Tunnel] Enumerating network events for socket 932
. 2016-05-16 19:39:01.092 [Tunnel] Enumerated 1 network events making 1 cumulative events for socket 932
. 2016-05-16 19:39:01.092 [Tunnel] Handling network read event on socket 932 with error 0
. 2016-05-16 19:39:01.092 [Tunnel] Doing Diffie-Hellman key exchange with hash SHA-256
. 2016-05-16 19:39:01.594 [Tunnel] Waiting for the server to continue with the initialization
. 2016-05-16 19:39:01.594 [Tunnel] Looking for incoming data
. 2016-05-16 19:39:01.594 [Tunnel] Looking for network events
. 2016-05-16 19:39:01.841 [Tunnel] Detected network event
. 2016-05-16 19:39:01.841 [Tunnel] Enumerating network events for socket 932
. 2016-05-16 19:39:01.841 [Tunnel] Enumerated 1 network events making 1 cumulative events for socket 932
. 2016-05-16 19:39:01.841 [Tunnel] Handling network read event on socket 932 with error 0
. 2016-05-16 19:39:02.383 [Tunnel] Verifying host key rsa2 0x23,0x9cc1cd1a8b1bd600 98fec84fcc70f635 081a17c3c011967b d118518b2da04608 3b59824f277dd899 0b841e83f318589d 8d9f9afaabff408d 6fb42bedc69bcf76 acdfd050f8eaece4 95647d5c1cda5a7a 1616df01297418ef a9a9475434e78e1c d63602304b8c60b4 908f5b8c32e58e03 13ec670aace6e2fd 71c18726b35187ab 300ad7a7bcb25d2f b6a37b83245a1137 18c95ae50c1db58f 5d3fb2656d0da785 47a77ccde56eeb7e 97498d341e2298c8 065309ae9da8ef51 580ba61e93b7a478 0562b962cff5f62e 97e0ae6e815eb848 1c50a4d6542c8d2c 19826965d5646de9 aea7f52a0ef0d729 6ebeae658081d5ad b1ddb96f60cf361d 25bf04c538ae927d with fingerprint ssh-rsa 2048 66:84:ae:f5:37:cd:95:76:8f:f4:73:6d:c0:30:7a:cf
. 2016-05-16 19:39:02.394 [Tunnel] Host key matches cached key
. 2016-05-16 19:39:02.394 [Tunnel] Selecting events 63 for socket 932
. 2016-05-16 19:39:02.395 [Tunnel] Host key fingerprint is:
. 2016-05-16 19:39:02.395 [Tunnel] ssh-rsa 2048 66:84:ae:f5:37:cd:95:76:8f:f4:73:6d:c0:30:7a:cf
. 2016-05-16 19:39:02.395 [Tunnel] Initialised AES-256 SDCTR client->server encryption
. 2016-05-16 19:39:02.395 [Tunnel] Initialised HMAC-SHA-256 client->server MAC algorithm
. 2016-05-16 19:39:02.395 [Tunnel] Initialised AES-256 SDCTR server->client encryption
. 2016-05-16 19:39:02.395 [Tunnel] Initialised HMAC-SHA-256 server->client MAC algorithm
. 2016-05-16 19:39:02.395 [Tunnel] Waiting for the server to continue with the initialization
. 2016-05-16 19:39:02.395 [Tunnel] Looking for incoming data
. 2016-05-16 19:39:02.395 [Tunnel] Looking for network events
. 2016-05-16 19:39:02.880 [Tunnel] Detected network event
. 2016-05-16 19:39:02.880 [Tunnel] Enumerating network events for socket 932
. 2016-05-16 19:39:02.880 [Tunnel] Enumerated 1 network events making 1 cumulative events for socket 932
. 2016-05-16 19:39:02.881 [Tunnel] Handling network read event on socket 932 with error 0
. 2016-05-16 19:39:02.881 [Tunnel] Reading private key file "C:\Users\candida\Desktop\gostode.ppk"
! 2016-05-16 19:39:02.881 [Tunnel] Using username "console-Z2MPld".
. 2016-05-16 19:39:02.895 [Tunnel] Waiting for the server to continue with the initialization
. 2016-05-16 19:39:02.895 [Tunnel] Looking for incoming data
. 2016-05-16 19:39:02.895 [Tunnel] Looking for network events
. 2016-05-16 19:39:03.124 [Tunnel] Detected network event
. 2016-05-16 19:39:03.124 [Tunnel] Enumerating network events for socket 932
. 2016-05-16 19:39:03.124 [Tunnel] Enumerated 1 network events making 1 cumulative events for socket 932
. 2016-05-16 19:39:03.124 [Tunnel] Handling network read event on socket 932 with error 0
. 2016-05-16 19:39:03.124 [Tunnel] Offered public key
. 2016-05-16 19:39:03.124 [Tunnel] Waiting for the server to continue with the initialization
. 2016-05-16 19:39:03.124 [Tunnel] Looking for incoming data
. 2016-05-16 19:39:03.124 [Tunnel] Looking for network events
. 2016-05-16 19:39:03.361 [Tunnel] Detected network event
. 2016-05-16 19:39:03.361 [Tunnel] Enumerating network events for socket 932
. 2016-05-16 19:39:03.361 [Tunnel] Enumerated 1 network events making 1 cumulative events for socket 932
. 2016-05-16 19:39:03.361 [Tunnel] Handling network read event on socket 932 with error 0
! 2016-05-16 19:39:03.361 [Tunnel] Server refused our key
. 2016-05-16 19:39:03.395 [Tunnel] Server refused our key
. 2016-05-16 19:39:03.395 [Tunnel] Prompt (password, "SSH password", <no instructions>, "&Password: ")
. 2016-05-16 19:39:03.395 [Tunnel] Using stored password.
. 2016-05-16 19:39:03.446 [Tunnel] Sent password
. 2016-05-16 19:39:03.446 [Tunnel] Waiting for the server to continue with the initialization
. 2016-05-16 19:39:03.446 [Tunnel] Looking for incoming data
. 2016-05-16 19:39:03.446 [Tunnel] Looking for network events
. 2016-05-16 19:39:03.672 [Tunnel] Detected network event
. 2016-05-16 19:39:03.672 [Tunnel] Enumerating network events for socket 932
. 2016-05-16 19:39:03.672 [Tunnel] Enumerated 1 network events making 1 cumulative events for socket 932
. 2016-05-16 19:39:03.672 [Tunnel] Handling network read event on socket 932 with error 0
. 2016-05-16 19:39:03.672 [Tunnel] Access granted
. 2016-05-16 19:39:03.673 [Tunnel] Updating forwarding socket 940 (1)
. 2016-05-16 19:39:03.673 [Tunnel] Selecting events 63 for socket 940
. 2016-05-16 19:39:03.673 [Tunnel] Updating forwarding socket 944 (1)
. 2016-05-16 19:39:03.673 [Tunnel] Selecting events 63 for socket 944
. 2016-05-16 19:39:03.673 [Tunnel] Local port 50000 forwarding to 26.108.43.2:22
. 2016-05-16 19:39:03.673 [Tunnel] Enumerating network events for socket 940
. 2016-05-16 19:39:03.673 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 940
. 2016-05-16 19:39:03.673 [Tunnel] Enumerating network events for socket 944
. 2016-05-16 19:39:03.674 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 944
. 2016-05-16 19:39:03.696 --------------------------------------------------------------------------
. 2016-05-16 19:39:03.697 [Tunnel] Looking for network events
. 2016-05-16 19:39:03.746 Connecting via tunnel interface 127.0.0.1:50000.
. 2016-05-16 19:39:03.797 Looking up host "127.0.0.1" (IPv4)
. 2016-05-16 19:39:03.797 Connecting to 127.0.0.1 port 50000
. 2016-05-16 19:39:03.797 Selecting events 63 for socket 960
. 2016-05-16 19:39:03.797 [Tunnel] Detected network event
. 2016-05-16 19:39:03.797 [Tunnel] Enumerating network events for socket 932
. 2016-05-16 19:39:03.797 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 932
. 2016-05-16 19:39:03.797 [Tunnel] Enumerating network events for socket 940
. 2016-05-16 19:39:03.797 [Tunnel] Enumerated 8 network events making 8 cumulative events for socket 940
. 2016-05-16 19:39:03.797 [Tunnel] Handling network accept event on socket 940 with error 0
. 2016-05-16 19:39:03.797 [Tunnel] Updating forwarding socket 976 (1)
. 2016-05-16 19:39:03.797 [Tunnel] Selecting events 63 for socket 976
. 2016-05-16 19:39:03.797 [Tunnel] Opening connection to 26.108.43.2:22 for forwarding
. 2016-05-16 19:39:03.798 [Tunnel] Enumerating network events for socket 944
. 2016-05-16 19:39:03.798 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 944
. 2016-05-16 19:39:03.798 [Tunnel] Enumerating network events for socket 976
. 2016-05-16 19:39:03.798 [Tunnel] Enumerated 2 network events making 2 cumulative events for socket 976
. 2016-05-16 19:39:03.798 [Tunnel] Handling network write event on socket 976 with error 0
. 2016-05-16 19:39:03.798 [Tunnel] Looking for network events
. 2016-05-16 19:39:03.798 [Tunnel] Detected network event
. 2016-05-16 19:39:03.798 [Tunnel] Enumerating network events for socket 932
. 2016-05-16 19:39:03.798 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 932
. 2016-05-16 19:39:03.798 [Tunnel] Enumerating network events for socket 940
. 2016-05-16 19:39:03.798 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 940
. 2016-05-16 19:39:03.798 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 976
. 2016-05-16 19:39:03.846 Waiting for the server to continue with the initialization
. 2016-05-16 19:39:03.846 Looking for incoming data
. 2016-05-16 19:39:03.846 Looking for network events
. 2016-05-16 19:39:03.846 Detected network event
. 2016-05-16 19:39:03.846 Enumerating network events for socket 960
. 2016-05-16 19:39:03.846 Enumerated 18 network events making 18 cumulative events for socket 960
. 2016-05-16 19:39:03.846 Handling network write event on socket 960 with error 0
. 2016-05-16 19:39:03.846 Handling network connect event on socket 960 with error 0
. 2016-05-16 19:39:04.020 [Tunnel] Detected network event
. 2016-05-16 19:39:04.020 [Tunnel] Enumerating network events for socket 932
. 2016-05-16 19:39:04.020 [Tunnel] Enumerated 1 network events making 1 cumulative events for socket 932
. 2016-05-16 19:39:04.020 [Tunnel] Handling network read event on socket 932 with error 0
. 2016-05-16 19:39:04.020 [Tunnel] Updating forwarding socket 976 (1)
. 2016-05-16 19:39:04.020 [Tunnel] Selecting events 63 for socket 976
. 2016-05-16 19:39:04.020 [Tunnel] Enumerating network events for socket 940
. 2016-05-16 19:39:04.020 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 940
. 2016-05-16 19:39:04.020 [Tunnel] Enumerating network events for socket 944
. 2016-05-16 19:39:04.020 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 944
. 2016-05-16 19:39:04.020 [Tunnel] Enumerating network events for socket 976
. 2016-05-16 19:39:04.020 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 976
. 2016-05-16 19:39:04.020 [Tunnel] Looking for network events
. 2016-05-16 19:39:04.270 [Tunnel] Timeout waiting for network events
. 2016-05-16 19:39:04.270 [Tunnel] Looking for network events
. 2016-05-16 19:39:04.442 [Tunnel] Detected network event
. 2016-05-16 19:39:04.442 [Tunnel] Enumerating network events for socket 932
. 2016-05-16 19:39:04.442 [Tunnel] Enumerated 1 network events making 1 cumulative events for socket 932
. 2016-05-16 19:39:04.442 [Tunnel] Handling network read event on socket 932 with error 0
. 2016-05-16 19:39:04.442 Detected network event
. 2016-05-16 19:39:04.442 [Tunnel] Enumerating network events for socket 940
. 2016-05-16 19:39:04.442 Enumerating network events for socket 960
. 2016-05-16 19:39:04.442 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 940
. 2016-05-16 19:39:04.442 Enumerated 1 network events making 1 cumulative events for socket 960
. 2016-05-16 19:39:04.442 [Tunnel] Enumerating network events for socket 944
. 2016-05-16 19:39:04.442 Handling network read event on socket 960 with error 0
. 2016-05-16 19:39:04.442 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 944
. 2016-05-16 19:39:04.442 Server version: SSH-2.0-OpenSSH_5.3
. 2016-05-16 19:39:04.442 [Tunnel] Enumerating network events for socket 976
. 2016-05-16 19:39:04.442 Using SSH protocol version 2
. 2016-05-16 19:39:04.442 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 976
. 2016-05-16 19:39:04.442 We claim version: SSH-2.0-WinSCP_release_5.7.7
. 2016-05-16 19:39:04.442 [Tunnel] Looking for network events
. 2016-05-16 19:39:04.442 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 932
. 2016-05-16 19:39:04.442 Waiting for the server to continue with the initialization
. 2016-05-16 19:39:04.442 Looking for incoming data
. 2016-05-16 19:39:04.442 Looking for network events
. 2016-05-16 19:39:04.443 [Tunnel] Enumerating network events for socket 976
. 2016-05-16 19:39:04.443 [Tunnel] Enumerated 1 network events making 1 cumulative events for socket 976
. 2016-05-16 19:39:04.443 [Tunnel] Handling network read event on socket 976 with error 0
. 2016-05-16 19:39:04.443 [Tunnel] Looking for network events
. 2016-05-16 19:39:04.669 [Tunnel] Detected network event
. 2016-05-16 19:39:04.669 [Tunnel] Enumerating network events for socket 932
. 2016-05-16 19:39:04.669 [Tunnel] Enumerated 1 network events making 1 cumulative events for socket 932
. 2016-05-16 19:39:04.669 [Tunnel] Handling network read event on socket 932 with error 0
. 2016-05-16 19:39:04.669 Detected network event
. 2016-05-16 19:39:04.669 [Tunnel] Enumerating network events for socket 940
. 2016-05-16 19:39:04.669 Enumerating network events for socket 960
. 2016-05-16 19:39:04.669 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 940
. 2016-05-16 19:39:04.669 Enumerated 1 network events making 1 cumulative events for socket 960
. 2016-05-16 19:39:04.669 [Tunnel] Enumerating network events for socket 944
. 2016-05-16 19:39:04.669 Handling network read event on socket 960 with error 0
. 2016-05-16 19:39:04.669 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 944
. 2016-05-16 19:39:04.669 [Tunnel] Enumerating network events for socket 976
. 2016-05-16 19:39:04.669 Server supports delayed compression; will try this later
. 2016-05-16 19:39:04.669 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 976
. 2016-05-16 19:39:04.669 Doing Diffie-Hellman group exchange
. 2016-05-16 19:39:04.669 [Tunnel] Looking for network events
. 2016-05-16 19:39:04.669 Waiting for the server to continue with the initialization
. 2016-05-16 19:39:04.669 Looking for incoming data
. 2016-05-16 19:39:04.669 Looking for network events
. 2016-05-16 19:39:04.669 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 932
. 2016-05-16 19:39:04.670 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 944
. 2016-05-16 19:39:04.670 [Tunnel] Enumerating network events for socket 976
. 2016-05-16 19:39:04.670 [Tunnel] Enumerated 1 network events making 1 cumulative events for socket 976
. 2016-05-16 19:39:04.670 [Tunnel] Handling network read event on socket 976 with error 0
. 2016-05-16 19:39:04.670 [Tunnel] Looking for network events
. 2016-05-16 19:39:04.901 [Tunnel] Detected network event
. 2016-05-16 19:39:04.901 [Tunnel] Enumerating network events for socket 932
. 2016-05-16 19:39:04.901 [Tunnel] Enumerated 1 network events making 1 cumulative events for socket 932
. 2016-05-16 19:39:04.901 [Tunnel] Handling network read event on socket 932 with error 0
. 2016-05-16 19:39:04.902 Detected network event
. 2016-05-16 19:39:04.902 Enumerating network events for socket 960
. 2016-05-16 19:39:04.902 Enumerated 1 network events making 1 cumulative events for socket 960
. 2016-05-16 19:39:04.902 Handling network read event on socket 960 with error 0
. 2016-05-16 19:39:04.902 Doing Diffie-Hellman key exchange with hash SHA-256
. 2016-05-16 19:39:04.934 [Tunnel] Enumerating network events for socket 940
. 2016-05-16 19:39:04.934 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 940
. 2016-05-16 19:39:04.934 [Tunnel] Enumerating network events for socket 944
. 2016-05-16 19:39:04.934 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 944
. 2016-05-16 19:39:04.934 [Tunnel] Enumerating network events for socket 976
. 2016-05-16 19:39:04.934 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 976
. 2016-05-16 19:39:04.934 [Tunnel] Looking for network events
. 2016-05-16 19:39:05.198 [Tunnel] Timeout waiting for network events
. 2016-05-16 19:39:05.198 [Tunnel] Looking for network events
. 2016-05-16 19:39:05.424 [Tunnel] Detected network event
. 2016-05-16 19:39:05.424 [Tunnel] Enumerating network events for socket 932
. 2016-05-16 19:39:05.424 Waiting for the server to continue with the initialization
. 2016-05-16 19:39:05.424 Looking for incoming data
. 2016-05-16 19:39:05.424 Looking for network events
. 2016-05-16 19:39:05.424 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 932
. 2016-05-16 19:39:05.424 [Tunnel] Enumerating network events for socket 940
. 2016-05-16 19:39:05.424 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 940
. 2016-05-16 19:39:05.425 [Tunnel] Enumerating network events for socket 944
. 2016-05-16 19:39:05.425 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 944
. 2016-05-16 19:39:05.425 [Tunnel] Enumerating network events for socket 976
. 2016-05-16 19:39:05.425 [Tunnel] Enumerated 1 network events making 1 cumulative events for socket 976
. 2016-05-16 19:39:05.425 [Tunnel] Handling network read event on socket 976 with error 0
. 2016-05-16 19:39:05.425 [Tunnel] Looking for network events
. 2016-05-16 19:39:05.658 [Tunnel] Detected network event
. 2016-05-16 19:39:05.658 [Tunnel] Enumerating network events for socket 932
. 2016-05-16 19:39:05.658 [Tunnel] Enumerated 1 network events making 1 cumulative events for socket 932
. 2016-05-16 19:39:05.658 [Tunnel] Handling network read event on socket 932 with error 0
. 2016-05-16 19:39:05.658 Detected network event
. 2016-05-16 19:39:05.658 [Tunnel] Enumerating network events for socket 940
. 2016-05-16 19:39:05.658 Enumerating network events for socket 960
. 2016-05-16 19:39:05.658 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 940
. 2016-05-16 19:39:05.658 Enumerated 1 network events making 1 cumulative events for socket 960
. 2016-05-16 19:39:05.658 [Tunnel] Enumerating network events for socket 944
. 2016-05-16 19:39:05.658 Handling network read event on socket 960 with error 0
. 2016-05-16 19:39:05.658 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 944
. 2016-05-16 19:39:05.658 [Tunnel] Enumerating network events for socket 976
. 2016-05-16 19:39:05.658 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 976
. 2016-05-16 19:39:05.658 [Tunnel] Looking for network events
. 2016-05-16 19:39:05.908 [Tunnel] Timeout waiting for network events
. 2016-05-16 19:39:05.908 [Tunnel] Looking for network events
. 2016-05-16 19:39:06.166 [Tunnel] Timeout waiting for network events
. 2016-05-16 19:39:06.166 [Tunnel] Looking for network events
. 2016-05-16 19:39:06.234 Verifying host key rsa2 0x23,0x9cc1cd1a8b8bd600 98fec84fcc70f635 081a17c3c411967b d118818b2da04608 3b59824f277dd599 0b841583f318589d 8d9ffafaabf5408d 6fb42bedc69bcf76 acdfd050f8eaece4 95647d5c1cda5a7a 1616df01297418ef a9a9475434e78e1c d63602304b8c60b4 908f5b8c32e58e03 13ec670aace6e2fd 71c18726b35187ab 300ad7a7bcb25d2f b6a37b83245a1137 18c95ae50c1db58f 5d3fb2656d0da785 47a77ccde56eeb7e 97498d341e2298c8 065309ae9da8ef51 580ba61e93b7a478 0562b962cff5f62e 97e0ae6e815eb848 1c50a4d6542c8d2c 19826965d5646de9 aea7f52a0ef0d729 6ebeae658081d5ad b1ddb96f60cf361d 25bf04c538ae927d with fingerprint ssh-rsa 2048 66:84:ae:f5:37:cd:95:76:8f:f4:73:6d:c0:30:7a:cf
. 2016-05-16 19:39:06.285 Host key matches cached key
. 2016-05-16 19:39:06.286 Selecting events 63 for socket 960
. 2016-05-16 19:39:06.286 Host key fingerprint is:
. 2016-05-16 19:39:06.286 ssh-rsa 2048 66:84:ae:f5:37:cd:95:76:8f:f4:73:6d:c0:30:7a:cf
. 2016-05-16 19:39:06.286 [Tunnel] Detected network event
. 2016-05-16 19:39:06.286 [Tunnel] Enumerating network events for socket 932
. 2016-05-16 19:39:06.286 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 932
. 2016-05-16 19:39:06.286 [Tunnel] Enumerating network events for socket 940
. 2016-05-16 19:39:06.286 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 940
. 2016-05-16 19:39:06.286 [Tunnel] Enumerating network events for socket 944
. 2016-05-16 19:39:06.286 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 944
. 2016-05-16 19:39:06.286 [Tunnel] Enumerating network events for socket 976
. 2016-05-16 19:39:06.286 [Tunnel] Enumerated 1 network events making 1 cumulative events for socket 976
. 2016-05-16 19:39:06.286 [Tunnel] Handling network read event on socket 976 with error 0
. 2016-05-16 19:39:06.286 [Tunnel] Looking for network events
. 2016-05-16 19:39:06.286 Initialised AES-256 SDCTR client->server encryption
. 2016-05-16 19:39:06.286 Initialised HMAC-SHA-256 client->server MAC algorithm
. 2016-05-16 19:39:06.287 Initialised AES-256 SDCTR server->client encryption
. 2016-05-16 19:39:06.287 Initialised HMAC-SHA-256 server->client MAC algorithm
. 2016-05-16 19:39:06.287 [Tunnel] Detected network event
. 2016-05-16 19:39:06.287 [Tunnel] Enumerating network events for socket 932
. 2016-05-16 19:39:06.287 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 932
. 2016-05-16 19:39:06.287 [Tunnel] Enumerating network events for socket 940
. 2016-05-16 19:39:06.287 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 940
. 2016-05-16 19:39:06.287 [Tunnel] Enumerating network events for socket 944
. 2016-05-16 19:39:06.287 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 944
. 2016-05-16 19:39:06.287 [Tunnel] Enumerating network events for socket 976
. 2016-05-16 19:39:06.287 [Tunnel] Enumerated 1 network events making 1 cumulative events for socket 976
. 2016-05-16 19:39:06.287 [Tunnel] Handling network read event on socket 976 with error 0
. 2016-05-16 19:39:06.287 [Tunnel] Looking for network events
. 2016-05-16 19:39:06.287 Waiting for the server to continue with the initialization
. 2016-05-16 19:39:06.287 Looking for incoming data
. 2016-05-16 19:39:06.287 Looking for network events
. 2016-05-16 19:39:06.537 [Tunnel] Timeout waiting for network events
. 2016-05-16 19:39:06.537 [Tunnel] Looking for network events
. 2016-05-16 19:39:06.771 [Tunnel] Detected network event
. 2016-05-16 19:39:06.771 [Tunnel] Enumerating network events for socket 932
. 2016-05-16 19:39:06.771 [Tunnel] Enumerated 1 network events making 1 cumulative events for socket 932
. 2016-05-16 19:39:06.772 [Tunnel] Handling network read event on socket 932 with error 0
. 2016-05-16 19:39:06.772 Detected network event
. 2016-05-16 19:39:06.772 [Tunnel] Enumerating network events for socket 940
. 2016-05-16 19:39:06.772 Enumerating network events for socket 960
. 2016-05-16 19:39:06.772 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 940
. 2016-05-16 19:39:06.772 Enumerated 1 network events making 1 cumulative events for socket 960
. 2016-05-16 19:39:06.772 [Tunnel] Enumerating network events for socket 944
. 2016-05-16 19:39:06.772 Handling network read event on socket 960 with error 0
. 2016-05-16 19:39:06.772 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 944
. 2016-05-16 19:39:06.772 [Tunnel] Enumerating network events for socket 976
! 2016-05-16 19:39:06.772 Using username "console-Z2MPld".
. 2016-05-16 19:39:06.772 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 976
. 2016-05-16 19:39:06.772 [Tunnel] Looking for network events
. 2016-05-16 19:39:06.784 Waiting for the server to continue with the initialization
. 2016-05-16 19:39:06.785 Looking for incoming data
. 2016-05-16 19:39:06.785 Looking for network events
. 2016-05-16 19:39:06.785 [Tunnel] Detected network event
. 2016-05-16 19:39:06.785 [Tunnel] Enumerating network events for socket 932
. 2016-05-16 19:39:06.785 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 932
. 2016-05-16 19:39:06.785 [Tunnel] Enumerating network events for socket 940
. 2016-05-16 19:39:06.785 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 940
. 2016-05-16 19:39:06.785 [Tunnel] Enumerating network events for socket 944
. 2016-05-16 19:39:06.785 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 944
. 2016-05-16 19:39:06.785 [Tunnel] Enumerating network events for socket 976
. 2016-05-16 19:39:06.785 [Tunnel] Enumerated 1 network events making 1 cumulative events for socket 976
. 2016-05-16 19:39:06.785 [Tunnel] Handling network read event on socket 976 with error 0
. 2016-05-16 19:39:06.785 [Tunnel] Looking for network events
. 2016-05-16 19:39:07.011 [Tunnel] Detected network event
. 2016-05-16 19:39:07.011 [Tunnel] Enumerating network events for socket 932
. 2016-05-16 19:39:07.011 [Tunnel] Enumerated 1 network events making 1 cumulative events for socket 932
. 2016-05-16 19:39:07.011 [Tunnel] Handling network read event on socket 932 with error 0
. 2016-05-16 19:39:07.011 Detected network event
. 2016-05-16 19:39:07.011 [Tunnel] Enumerating network events for socket 940
. 2016-05-16 19:39:07.011 Enumerating network events for socket 960
. 2016-05-16 19:39:07.011 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 940
. 2016-05-16 19:39:07.011 Enumerated 1 network events making 1 cumulative events for socket 960
. 2016-05-16 19:39:07.011 [Tunnel] Enumerating network events for socket 944
. 2016-05-16 19:39:07.011 Handling network read event on socket 960 with error 0
. 2016-05-16 19:39:07.011 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 944
. 2016-05-16 19:39:07.011 [Tunnel] Enumerating network events for socket 976
. 2016-05-16 19:39:07.011 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 976
. 2016-05-16 19:39:07.011 [Tunnel] Looking for network events
. 2016-05-16 19:39:07.011 Prompt (password, "SSH password", <no instructions>, "&Password: ")
. 2016-05-16 19:39:07.011 Using stored password.
. 2016-05-16 19:39:07.035 Sent password
. 2016-05-16 19:39:07.035 Waiting for the server to continue with the initialization
. 2016-05-16 19:39:07.035 Looking for incoming data
. 2016-05-16 19:39:07.035 Looking for network events
. 2016-05-16 19:39:07.035 [Tunnel] Detected network event
. 2016-05-16 19:39:07.035 [Tunnel] Enumerating network events for socket 932
. 2016-05-16 19:39:07.035 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 932
. 2016-05-16 19:39:07.035 [Tunnel] Enumerating network events for socket 940
. 2016-05-16 19:39:07.035 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 940
. 2016-05-16 19:39:07.035 [Tunnel] Enumerating network events for socket 944
. 2016-05-16 19:39:07.035 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 944
. 2016-05-16 19:39:07.035 [Tunnel] Enumerating network events for socket 976
. 2016-05-16 19:39:07.035 [Tunnel] Enumerated 1 network events making 1 cumulative events for socket 976
. 2016-05-16 19:39:07.035 [Tunnel] Handling network read event on socket 976 with error 0
. 2016-05-16 19:39:07.035 [Tunnel] Looking for network events
. 2016-05-16 19:39:07.259 [Tunnel] Detected network event
. 2016-05-16 19:39:07.259 [Tunnel] Enumerating network events for socket 932
. 2016-05-16 19:39:07.259 [Tunnel] Enumerated 1 network events making 1 cumulative events for socket 932
. 2016-05-16 19:39:07.259 [Tunnel] Handling network read event on socket 932 with error 0
. 2016-05-16 19:39:07.259 Detected network event
. 2016-05-16 19:39:07.259 [Tunnel] Enumerating network events for socket 940
. 2016-05-16 19:39:07.259 Enumerating network events for socket 960
. 2016-05-16 19:39:07.259 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 940
. 2016-05-16 19:39:07.259 Enumerated 1 network events making 1 cumulative events for socket 960
. 2016-05-16 19:39:07.259 [Tunnel] Enumerating network events for socket 944
. 2016-05-16 19:39:07.259 Handling network read event on socket 960 with error 0
. 2016-05-16 19:39:07.259 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 944
. 2016-05-16 19:39:07.260 Access granted
. 2016-05-16 19:39:07.260 Initiating key re-exchange (enabling delayed compression)
. 2016-05-16 19:39:07.260 [Tunnel] Enumerating network events for socket 976
. 2016-05-16 19:39:07.260 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 976
. 2016-05-16 19:39:07.260 [Tunnel] Looking for network events
. 2016-05-16 19:39:07.260 [Tunnel] Detected network event
. 2016-05-16 19:39:07.270 Opening session as main channel
. 2016-05-16 19:39:07.270 [Tunnel] Enumerating network events for socket 932
. 2016-05-16 19:39:07.270 Waiting for the server to continue with the initialization
. 2016-05-16 19:39:07.270 Looking for incoming data
. 2016-05-16 19:39:07.270 Looking for network events
. 2016-05-16 19:39:07.270 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 932
. 2016-05-16 19:39:07.270 [Tunnel] Enumerating network events for socket 940
. 2016-05-16 19:39:07.270 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 940
. 2016-05-16 19:39:07.270 [Tunnel] Enumerating network events for socket 944
. 2016-05-16 19:39:07.270 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 944
. 2016-05-16 19:39:07.270 [Tunnel] Enumerating network events for socket 976
. 2016-05-16 19:39:07.270 [Tunnel] Enumerated 1 network events making 1 cumulative events for socket 976
. 2016-05-16 19:39:07.270 [Tunnel] Handling network read event on socket 976 with error 0
. 2016-05-16 19:39:07.270 [Tunnel] Looking for network events
. 2016-05-16 19:39:07.496 [Tunnel] Detected network event
. 2016-05-16 19:39:07.497 [Tunnel] Enumerating network events for socket 932
. 2016-05-16 19:39:07.497 [Tunnel] Enumerated 1 network events making 1 cumulative events for socket 932
. 2016-05-16 19:39:07.497 [Tunnel] Handling network read event on socket 932 with error 0
. 2016-05-16 19:39:07.497 Detected network event
. 2016-05-16 19:39:07.497 [Tunnel] Enumerating network events for socket 940
. 2016-05-16 19:39:07.497 Enumerating network events for socket 960
. 2016-05-16 19:39:07.497 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 940
. 2016-05-16 19:39:07.497 Enumerated 1 network events making 1 cumulative events for socket 960
. 2016-05-16 19:39:07.497 [Tunnel] Enumerating network events for socket 944
. 2016-05-16 19:39:07.497 Handling network read event on socket 960 with error 0
. 2016-05-16 19:39:07.497 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 944
. 2016-05-16 19:39:07.497 [Tunnel] Enumerating network events for socket 976
. 2016-05-16 19:39:07.497 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 976
. 2016-05-16 19:39:07.497 [Tunnel] Looking for network events
. 2016-05-16 19:39:07.497 Doing Diffie-Hellman group exchange
. 2016-05-16 19:39:07.497 [Tunnel] Detected network event
. 2016-05-16 19:39:07.497 Waiting for the server to continue with the initialization
. 2016-05-16 19:39:07.497 Looking for incoming data
. 2016-05-16 19:39:07.497 Looking for network events
. 2016-05-16 19:39:07.497 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 932
. 2016-05-16 19:39:07.497 [Tunnel] Enumerated 1 network events making 1 cumulative events for socket 976
. 2016-05-16 19:39:07.497 [Tunnel] Handling network read event on socket 976 with error 0
. 2016-05-16 19:39:07.498 [Tunnel] Looking for network events
. 2016-05-16 19:39:07.734 [Tunnel] Detected network event
. 2016-05-16 19:39:07.734 [Tunnel] Enumerating network events for socket 932
. 2016-05-16 19:39:07.734 [Tunnel] Enumerated 1 network events making 1 cumulative events for socket 932
. 2016-05-16 19:39:07.734 [Tunnel] Handling network read event on socket 932 with error 0
. 2016-05-16 19:39:07.734 Detected network event
. 2016-05-16 19:39:07.734 [Tunnel] Enumerating network events for socket 940
. 2016-05-16 19:39:07.734 Enumerating network events for socket 960
. 2016-05-16 19:39:07.734 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 940
. 2016-05-16 19:39:07.734 Enumerated 1 network events making 1 cumulative events for socket 960
. 2016-05-16 19:39:07.734 [Tunnel] Enumerating network events for socket 944
. 2016-05-16 19:39:07.734 Handling network read event on socket 960 with error 0
. 2016-05-16 19:39:07.734 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 944
. 2016-05-16 19:39:07.734 [Tunnel] Enumerating network events for socket 976
. 2016-05-16 19:39:07.734 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 976
. 2016-05-16 19:39:07.734 Doing Diffie-Hellman key exchange with hash SHA-256
. 2016-05-16 19:39:07.734 [Tunnel] Looking for network events
. 2016-05-16 19:39:07.984 [Tunnel] Timeout waiting for network events
. 2016-05-16 19:39:07.984 [Tunnel] Looking for network events
. 2016-05-16 19:39:08.232 [Tunnel] Detected network event
. 2016-05-16 19:39:08.232 Waiting for the server to continue with the initialization
. 2016-05-16 19:39:08.232 Looking for incoming data
. 2016-05-16 19:39:08.232 Looking for network events
. 2016-05-16 19:39:08.232 [Tunnel] Enumerating network events for socket 932
. 2016-05-16 19:39:08.232 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 932
. 2016-05-16 19:39:08.232 [Tunnel] Enumerating network events for socket 940
. 2016-05-16 19:39:08.232 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 940
. 2016-05-16 19:39:08.232 [Tunnel] Enumerating network events for socket 944
. 2016-05-16 19:39:08.232 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 944
. 2016-05-16 19:39:08.232 [Tunnel] Enumerating network events for socket 976
. 2016-05-16 19:39:08.232 [Tunnel] Enumerated 1 network events making 1 cumulative events for socket 976
. 2016-05-16 19:39:08.232 [Tunnel] Handling network read event on socket 976 with error 0
. 2016-05-16 19:39:08.233 [Tunnel] Looking for network events
. 2016-05-16 19:39:08.468 [Tunnel] Detected network event
. 2016-05-16 19:39:08.468 [Tunnel] Enumerating network events for socket 932
. 2016-05-16 19:39:08.468 [Tunnel] Enumerated 1 network events making 1 cumulative events for socket 932
. 2016-05-16 19:39:08.468 [Tunnel] Handling network read event on socket 932 with error 0
. 2016-05-16 19:39:08.468 Detected network event
. 2016-05-16 19:39:08.468 [Tunnel] Enumerating network events for socket 940
. 2016-05-16 19:39:08.468 Enumerating network events for socket 960
. 2016-05-16 19:39:08.468 Enumerated 1 network events making 1 cumulative events for socket 960
. 2016-05-16 19:39:08.468 Handling network read event on socket 960 with error 0
. 2016-05-16 19:39:08.478 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 940
. 2016-05-16 19:39:08.478 [Tunnel] Enumerating network events for socket 944
. 2016-05-16 19:39:08.478 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 944
. 2016-05-16 19:39:08.478 [Tunnel] Enumerating network events for socket 976
. 2016-05-16 19:39:08.478 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 976
. 2016-05-16 19:39:08.478 [Tunnel] Looking for network events
. 2016-05-16 19:39:08.728 [Tunnel] Timeout waiting for network events
. 2016-05-16 19:39:08.728 [Tunnel] Looking for network events
. 2016-05-16 19:39:08.978 [Tunnel] Timeout waiting for network events
. 2016-05-16 19:39:08.978 [Tunnel] Looking for network events
. 2016-05-16 19:39:09.006 [Tunnel] Detected network event
. 2016-05-16 19:39:09.006 [Tunnel] Enumerating network events for socket 932
. 2016-05-16 19:39:09.006 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 932
. 2016-05-16 19:39:09.006 [Tunnel] Enumerating network events for socket 940
. 2016-05-16 19:39:09.006 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 940
. 2016-05-16 19:39:09.006 [Tunnel] Enumerating network events for socket 944
. 2016-05-16 19:39:09.006 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 944
. 2016-05-16 19:39:09.006 [Tunnel] Enumerating network events for socket 976
. 2016-05-16 19:39:09.006 [Tunnel] Enumerated 1 network events making 1 cumulative events for socket 976
. 2016-05-16 19:39:09.006 [Tunnel] Handling network read event on socket 976 with error 0
. 2016-05-16 19:39:09.006 Initialised AES-256 SDCTR client->server encryption
. 2016-05-16 19:39:09.007 Initialised HMAC-SHA-256 client->server MAC algorithm
. 2016-05-16 19:39:09.007 Initialised zlib (RFC1950) compression
. 2016-05-16 19:39:09.007 [Tunnel] Looking for network events
. 2016-05-16 19:39:09.007 [Tunnel] Detected network event
. 2016-05-16 19:39:09.007 [Tunnel] Enumerating network events for socket 932
. 2016-05-16 19:39:09.007 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 932
. 2016-05-16 19:39:09.007 [Tunnel] Enumerating network events for socket 940
. 2016-05-16 19:39:09.007 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 940
. 2016-05-16 19:39:09.007 [Tunnel] Enumerating network events for socket 944
. 2016-05-16 19:39:09.007 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 944
. 2016-05-16 19:39:09.007 [Tunnel] Enumerating network events for socket 976
. 2016-05-16 19:39:09.007 [Tunnel] Enumerated 1 network events making 1 cumulative events for socket 976
. 2016-05-16 19:39:09.007 [Tunnel] Handling network read event on socket 976 with error 0
. 2016-05-16 19:39:09.007 Initialised AES-256 SDCTR server->client encryption
. 2016-05-16 19:39:09.007 Initialised HMAC-SHA-256 server->client MAC algorithm
. 2016-05-16 19:39:09.007 Initialised zlib (RFC1950) decompression
. 2016-05-16 19:39:09.007 Waiting for the server to continue with the initialization
. 2016-05-16 19:39:09.007 Looking for incoming data
. 2016-05-16 19:39:09.007 Looking for network events
. 2016-05-16 19:39:09.257 [Tunnel] Timeout waiting for network events
. 2016-05-16 19:39:09.257 [Tunnel] Looking for network events
. 2016-05-16 19:39:09.491 [Tunnel] Detected network event
. 2016-05-16 19:39:09.491 [Tunnel] Enumerating network events for socket 932
. 2016-05-16 19:39:09.492 [Tunnel] Enumerated 1 network events making 1 cumulative events for socket 932
. 2016-05-16 19:39:09.492 [Tunnel] Handling network read event on socket 932 with error 0
. 2016-05-16 19:39:09.492 Detected network event
. 2016-05-16 19:39:09.492 [Tunnel] Enumerating network events for socket 940
. 2016-05-16 19:39:09.492 Enumerating network events for socket 960
. 2016-05-16 19:39:09.492 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 940
. 2016-05-16 19:39:09.492 Enumerated 1 network events making 1 cumulative events for socket 960
. 2016-05-16 19:39:09.492 [Tunnel] Enumerating network events for socket 944
. 2016-05-16 19:39:09.492 Handling network read event on socket 960 with error 0
. 2016-05-16 19:39:09.492 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 944
. 2016-05-16 19:39:09.492 [Tunnel] Enumerating network events for socket 976
. 2016-05-16 19:39:09.492 Opened main channel
. 2016-05-16 19:39:09.492 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 976
. 2016-05-16 19:39:09.492 [Tunnel] Looking for network events
. 2016-05-16 19:39:09.492 [Tunnel] Detected network event
. 2016-05-16 19:39:09.492 [Tunnel] Enumerating network events for socket 932
. 2016-05-16 19:39:09.492 Waiting for the server to continue with the initialization
. 2016-05-16 19:39:09.492 Looking for incoming data
. 2016-05-16 19:39:09.492 Looking for network events
. 2016-05-16 19:39:09.492 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 932
. 2016-05-16 19:39:09.492 [Tunnel] Enumerated 1 network events making 1 cumulative events for socket 976
. 2016-05-16 19:39:09.492 [Tunnel] Handling network read event on socket 976 with error 0
. 2016-05-16 19:39:09.716 [Tunnel] Detected network event
. 2016-05-16 19:39:09.716 [Tunnel] Enumerating network events for socket 932
. 2016-05-16 19:39:09.716 [Tunnel] Enumerated 1 network events making 1 cumulative events for socket 932
. 2016-05-16 19:39:09.716 [Tunnel] Handling network read event on socket 932 with error 0
. 2016-05-16 19:39:09.716 Detected network event
. 2016-05-16 19:39:09.716 [Tunnel] Enumerating network events for socket 940
. 2016-05-16 19:39:09.716 Enumerating network events for socket 960
. 2016-05-16 19:39:09.716 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 940
. 2016-05-16 19:39:09.716 Enumerated 1 network events making 1 cumulative events for socket 960
. 2016-05-16 19:39:09.716 [Tunnel] Enumerating network events for socket 944
. 2016-05-16 19:39:09.717 Handling network read event on socket 960 with error 0
. 2016-05-16 19:39:09.717 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 944
. 2016-05-16 19:39:09.717 [Tunnel] Enumerating network events for socket 976
. 2016-05-16 19:39:09.717 Started a shell/command
. 2016-05-16 19:39:09.717 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 976
. 2016-05-16 19:39:09.717 [Tunnel] Looking for network events
. 2016-05-16 19:39:09.734 --------------------------------------------------------------------------
. 2016-05-16 19:39:09.734 Using SCP protocol.
. 2016-05-16 19:39:09.735 Doing startup conversation with host.
. 2016-05-16 19:39:09.735 Session upkeep
. 2016-05-16 19:39:09.735 Looking for network events
. 2016-05-16 19:39:09.735 Timeout waiting for network events
. 2016-05-16 19:39:09.785 Skipping host startup message (if any).
> 2016-05-16 19:39:09.785 echo "WinSCP: this is end-of-file:$?"
. 2016-05-16 19:39:09.786 [Tunnel] Detected network event
. 2016-05-16 19:39:09.786 [Tunnel] Enumerating network events for socket 932
. 2016-05-16 19:39:09.786 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 932
. 2016-05-16 19:39:09.786 [Tunnel] Enumerating network events for socket 940
. 2016-05-16 19:39:09.786 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 940
. 2016-05-16 19:39:09.786 [Tunnel] Enumerating network events for socket 944
. 2016-05-16 19:39:09.786 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 944
. 2016-05-16 19:39:09.786 [Tunnel] Enumerating network events for socket 976
. 2016-05-16 19:39:09.786 [Tunnel] Enumerated 1 network events making 1 cumulative events for socket 976
. 2016-05-16 19:39:09.786 [Tunnel] Handling network read event on socket 976 with error 0
. 2016-05-16 19:39:09.786 [Tunnel] Looking for network events
. 2016-05-16 19:39:09.786 Sent 38 bytes
. 2016-05-16 19:39:09.786 There are 0 bytes remaining in the send buffer
. 2016-05-16 19:39:09.786 Looking for network events
. 2016-05-16 19:39:09.786 Timeout waiting for network events
. 2016-05-16 19:39:09.786 Waiting for another 1 bytes
. 2016-05-16 19:39:09.786 Looking for incoming data
. 2016-05-16 19:39:10.010 [Tunnel] Detected network event
. 2016-05-16 19:39:10.010 [Tunnel] Enumerating network events for socket 932
. 2016-05-16 19:39:10.010 [Tunnel] Enumerated 1 network events making 1 cumulative events for socket 932
. 2016-05-16 19:39:10.010 [Tunnel] Handling network read event on socket 932 with error 0
. 2016-05-16 19:39:10.010 Detected network event
. 2016-05-16 19:39:10.010 Enumerating network events for socket 960
. 2016-05-16 19:39:10.010 Enumerated 1 network events making 1 cumulative events for socket 960
. 2016-05-16 19:39:10.010 Handling network read event on socket 960 with error 0
. 2016-05-16 19:39:10.010 [Tunnel] Enumerating network events for socket 940
. 2016-05-16 19:39:10.010 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 940
. 2016-05-16 19:39:10.010 Received 82 bytes (1)
. 2016-05-16 19:39:10.010 [Tunnel] Enumerating network events for socket 944
! 2016-05-16 19:39:10.010 Could not chdir to home directory /home/console-Z2MPld: No such file or directory
. 2016-05-16 19:39:10.010 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 944
. 2016-05-16 19:39:10.011 [Tunnel] Enumerating network events for socket 976
. 2016-05-16 19:39:10.011 Received 42 bytes (1)
! 2016-05-16 19:39:10.011 Unable to get term attr: Invalid argument
. 2016-05-16 19:39:10.011 Received 16 bytes (0)
. 2016-05-16 19:39:10.011 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 976
. 2016-05-16 19:39:10.011 Read 1 bytes (15 pending)
. 2016-05-16 19:39:10.011 Read 15 bytes (0 pending)
. 2016-05-16 19:39:10.011 [Tunnel] Looking for network events
. 2016-05-16 19:39:10.011 Waiting for another 1 bytes
. 2016-05-16 19:39:10.011 Looking for incoming data
. 2016-05-16 19:39:10.011 Looking for network events
. 2016-05-16 19:39:10.011 Detected network event
. 2016-05-16 19:39:10.011 Enumerating network events for socket 960
. 2016-05-16 19:39:10.011 Enumerated 0 network events making 0 cumulative events for socket 960
. 2016-05-16 19:39:10.261 [Tunnel] Timeout waiting for network events
. 2016-05-16 19:39:10.261 [Tunnel] Looking for network events
. 2016-05-16 19:39:10.439 [Tunnel] Detected network event
. 2016-05-16 19:39:10.439 [Tunnel] Enumerating network events for socket 932
. 2016-05-16 19:39:10.439 [Tunnel] Enumerated 1 network events making 1 cumulative events for socket 932
. 2016-05-16 19:39:10.439 [Tunnel] Handling network read event on socket 932 with error 0
. 2016-05-16 19:39:10.439 Detected network event
. 2016-05-16 19:39:10.439 [Tunnel] Enumerating network events for socket 940
. 2016-05-16 19:39:10.439 Enumerating network events for socket 960
. 2016-05-16 19:39:10.439 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 940
. 2016-05-16 19:39:10.439 Enumerated 1 network events making 1 cumulative events for socket 960
. 2016-05-16 19:39:10.439 [Tunnel] Enumerating network events for socket 944
. 2016-05-16 19:39:10.439 Handling network read event on socket 960 with error 0
. 2016-05-16 19:39:10.439 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 944
. 2016-05-16 19:39:10.439 [Tunnel] Enumerating network events for socket 976
. 2016-05-16 19:39:10.439 Received 46 bytes (0)
. 2016-05-16 19:39:10.439 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 976
. 2016-05-16 19:39:10.439 Read 1 bytes (45 pending)
. 2016-05-16 19:39:10.439 Read 29 bytes (16 pending)
. 2016-05-16 19:39:10.439 [Tunnel] Looking for network events
< 2016-05-16 19:39:10.439 root@dom:/# WinSCP: this is end-of-file:0
> 2016-05-16 19:39:10.439 echo $LANG ; echo "WinSCP: this is end-of-file:$?"
. 2016-05-16 19:39:10.440 [Tunnel] Detected network event
. 2016-05-16 19:39:10.440 [Tunnel] Enumerating network events for socket 932
. 2016-05-16 19:39:10.440 Sent 51 bytes
. 2016-05-16 19:39:10.440 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 932
. 2016-05-16 19:39:10.440 There are 0 bytes remaining in the send buffer
. 2016-05-16 19:39:10.440 [Tunnel] Enumerating network events for socket 940
. 2016-05-16 19:39:10.440 Looking for network events
. 2016-05-16 19:39:10.440 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 940
. 2016-05-16 19:39:10.440 Timeout waiting for network events
. 2016-05-16 19:39:10.440 [Tunnel] Enumerating network events for socket 944
. 2016-05-16 19:39:10.440 Read 16 bytes (0 pending)
. 2016-05-16 19:39:10.440 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 944
. 2016-05-16 19:39:10.450 Waiting for another 1 bytes
. 2016-05-16 19:39:10.450 [Tunnel] Enumerating network events for socket 976
. 2016-05-16 19:39:10.450 Looking for incoming data
. 2016-05-16 19:39:10.450 Looking for network events
. 2016-05-16 19:39:10.450 [Tunnel] Enumerated 1 network events making 1 cumulative events for socket 976
. 2016-05-16 19:39:10.450 [Tunnel] Handling network read event on socket 976 with error 0
. 2016-05-16 19:39:10.450 [Tunnel] Looking for network events
. 2016-05-16 19:39:10.675 [Tunnel] Detected network event
. 2016-05-16 19:39:10.675 [Tunnel] Enumerating network events for socket 932
. 2016-05-16 19:39:10.675 [Tunnel] Enumerated 1 network events making 1 cumulative events for socket 932
. 2016-05-16 19:39:10.675 [Tunnel] Handling network read event on socket 932 with error 0
. 2016-05-16 19:39:10.675 [Tunnel] Enumerating network events for socket 940
. 2016-05-16 19:39:10.675 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 940
. 2016-05-16 19:39:10.675 [Tunnel] Enumerating network events for socket 944
. 2016-05-16 19:39:10.675 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 944
. 2016-05-16 19:39:10.675 [Tunnel] Enumerating network events for socket 976
. 2016-05-16 19:39:10.675 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 976
. 2016-05-16 19:39:10.675 Detected network event
. 2016-05-16 19:39:10.675 [Tunnel] Looking for network events
. 2016-05-16 19:39:10.675 Enumerating network events for socket 960
. 2016-05-16 19:39:10.675 Enumerated 1 network events making 1 cumulative events for socket 960
. 2016-05-16 19:39:10.675 Handling network read event on socket 960 with error 0
. 2016-05-16 19:39:10.675 Received 47 bytes (0)
. 2016-05-16 19:39:10.675 Read 1 bytes (46 pending)
< 2016-05-16 19:39:10.675 root@dom:/#
. 2016-05-16 19:39:10.675 Read 30 bytes (16 pending)
< 2016-05-16 19:39:10.675 WinSCP: this is end-of-file:0
. 2016-05-16 19:39:10.675 We will not use UTF-8
. 2016-05-16 19:39:10.676 Clearing all aliases.
> 2016-05-16 19:39:10.676 unalias "ls" ; echo "WinSCP: this is end-of-file:$?"
. 2016-05-16 19:39:10.676 [Tunnel] Detected network event
. 2016-05-16 19:39:10.676 Sent 53 bytes
. 2016-05-16 19:39:10.676 [Tunnel] Enumerating network events for socket 932
. 2016-05-16 19:39:10.676 There are 0 bytes remaining in the send buffer
. 2016-05-16 19:39:10.676 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 932
. 2016-05-16 19:39:10.676 Looking for network events
. 2016-05-16 19:39:10.676 [Tunnel] Enumerating network events for socket 940
. 2016-05-16 19:39:10.676 Timeout waiting for network events
. 2016-05-16 19:39:10.676 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 940
. 2016-05-16 19:39:10.676 Read 16 bytes (0 pending)
. 2016-05-16 19:39:10.676 [Tunnel] Enumerating network events for socket 944
. 2016-05-16 19:39:10.676 Waiting for another 1 bytes
. 2016-05-16 19:39:10.676 Looking for incoming data
. 2016-05-16 19:39:10.676 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 944
. 2016-05-16 19:39:10.676 [Tunnel] Enumerating network events for socket 976
. 2016-05-16 19:39:10.676 [Tunnel] Enumerated 1 network events making 1 cumulative events for socket 976
. 2016-05-16 19:39:10.676 [Tunnel] Handling network read event on socket 976 with error 0
. 2016-05-16 19:39:10.676 [Tunnel] Looking for network events
. 2016-05-16 19:39:10.902 [Tunnel] Detected network event
. 2016-05-16 19:39:10.902 [Tunnel] Enumerating network events for socket 932
. 2016-05-16 19:39:10.902 [Tunnel] Enumerated 1 network events making 1 cumulative events for socket 932
. 2016-05-16 19:39:10.902 [Tunnel] Handling network read event on socket 932 with error 0
. 2016-05-16 19:39:10.903 Detected network event
. 2016-05-16 19:39:10.903 [Tunnel] Enumerating network events for socket 940
. 2016-05-16 19:39:10.903 Enumerating network events for socket 960
. 2016-05-16 19:39:10.903 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 940
. 2016-05-16 19:39:10.903 Enumerated 1 network events making 1 cumulative events for socket 960
. 2016-05-16 19:39:10.903 [Tunnel] Enumerating network events for socket 944
. 2016-05-16 19:39:10.903 Handling network read event on socket 960 with error 0
. 2016-05-16 19:39:10.903 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 944
. 2016-05-16 19:39:10.903 [Tunnel] Enumerating network events for socket 976
. 2016-05-16 19:39:10.903 Received 46 bytes (0)
. 2016-05-16 19:39:10.903 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 976
. 2016-05-16 19:39:10.903 Read 1 bytes (45 pending)
. 2016-05-16 19:39:10.903 Read 29 bytes (16 pending)
. 2016-05-16 19:39:10.903 [Tunnel] Looking for network events
< 2016-05-16 19:39:10.903 root@dom:/# WinSCP: this is end-of-file:0
> 2016-05-16 19:39:10.903 unalias "echo" ; echo "WinSCP: this is end-of-file:$?"
. 2016-05-16 19:39:10.903 [Tunnel] Detected network event
. 2016-05-16 19:39:10.903 [Tunnel] Enumerating network events for socket 932
. 2016-05-16 19:39:10.903 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 932
. 2016-05-16 19:39:10.903 [Tunnel] Enumerated 1 network events making 1 cumulative events for socket 976
. 2016-05-16 19:39:10.903 [Tunnel] Handling network read event on socket 976 with error 0
. 2016-05-16 19:39:10.903 Sent 55 bytes
. 2016-05-16 19:39:10.903 There are 0 bytes remaining in the send buffer
. 2016-05-16 19:39:10.904 Looking for network events
. 2016-05-16 19:39:10.904 Timeout waiting for network events
. 2016-05-16 19:39:10.904 Read 16 bytes (0 pending)
. 2016-05-16 19:39:10.904 Waiting for another 1 bytes
. 2016-05-16 19:39:10.904 Looking for incoming data
. 2016-05-16 19:39:11.129 [Tunnel] Detected network event
. 2016-05-16 19:39:11.129 [Tunnel] Enumerating network events for socket 932
. 2016-05-16 19:39:11.129 [Tunnel] Enumerated 1 network events making 1 cumulative events for socket 932
. 2016-05-16 19:39:11.129 [Tunnel] Handling network read event on socket 932 with error 0
. 2016-05-16 19:39:11.129 Detected network event
. 2016-05-16 19:39:11.129 [Tunnel] Enumerating network events for socket 940
. 2016-05-16 19:39:11.129 Enumerating network events for socket 960
. 2016-05-16 19:39:11.129 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 940
. 2016-05-16 19:39:11.129 Enumerated 1 network events making 1 cumulative events for socket 960
. 2016-05-16 19:39:11.129 [Tunnel] Enumerating network events for socket 944
. 2016-05-16 19:39:11.129 Handling network read event on socket 960 with error 0
. 2016-05-16 19:39:11.130 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 944
. 2016-05-16 19:39:11.130 [Tunnel] Enumerating network events for socket 976
. 2016-05-16 19:39:11.130 Received 78 bytes (0)
. 2016-05-16 19:39:11.130 [Tunnel] Enumerated 0 network events making 0 cumulative events for socket 976
. 2016-05-16 19:39:11.130 Read 1 bytes (77 pending)
. 2016-05-16 19:39:11.130 Read 31 bytes (46 pending)
. 2016-05-16 19:39:11.130 [Tunnel] Looking for network events
< 2016-05-16 19:39:11.130 root@dom:/# -bash: unalias: echo: not found
. 2016-05-16 19:39:11.130 Read 30 bytes (16 pending)
< 2016-05-16 19:39:11.130 WinSCP: this is end-of-file:1
> 2016-05-16 19:39:11.130 unalias "pwd" ; echo "WinSCP: this is end-of-file:$?"
Why are you using SCP in the first place? Did you try SFTP?
