Topic "WinSCP 5.8.2 automation error"
Lukas Filim
Hi Support,
I'm using latest version 5.8.2 with SFTP protocol on Windows Server 2008 R2.
I'm getting an error :
<failure>
<message>Cannot initialize external console.</message>
<message>Request event</message>
<message>System Error. Code: 5.</message>
<message>Access is denied</message>
</failure>
Can you let me know how to resolve this error?
I'm attaching a full debug log that I've created. I want to add that debug log and normal log location is the same.
Best Regards,
Lukas
log-6392510.zip (2.25 KB) [Download]
Description: (none)
Lukas FIlim
Hi ,
I'm also getting second error : Cannot initialize external console.
I know I have write permissions in web application and in c:\windows\temp\ however I'm missing something here.
Best Regards,
Lukas
Can you describe the environment that you are using WinSCP .NET assembly in?
Lukas Filim
I'm running Win SCP o Windows Server 2008 R2 which is one of 2 web servers which are managed by Load Balancer.
What else would you liek to know?
So do you run WinSCP from your website code? Is it IIS/ASP?
Lukas Filim
Yes I'm running WinSCp from website code that runs on IIS7 with .Net 4.0
You might need to set the Session.ExecutableProcessUserName and Session.ExecutableProcessPassword (available in WinSCP 5.8.x RC only).
See
https://winscp.net/tracker/show_bug.cgi?id=1334
https://winscp.net/eng/docs/message_cannot_initialize_external_console
Lukas Filim
Hi Martin,
I've used both fields : Session.ExecutableProcessUserName and Session.ExecutableProcessPassword
I've set them to use admin user on the server and error 'Cannot initialize external console.Request event.System Error. Code: 5.Access is denied.' is gone however I'm getting another error : System.ComponentModel.Win32Exception (0x80004005): Access is denied at System.Diagnostics.Process.StartWithCreateProcess(ProcessStartInfo startInfo)
I found on web that this can be caused by incorrect login details or super user. I can use normal version of WinSCP not thru .Net component on the same server and connect. How can I resolve this error??
Best Regards,
Lukas
