Topic "transfer file without having to navigate to it"
bheinsius
I sometimes have a fully qualified file name in my clipboard that i want to transfer, like /home/bart/dir1/dir2/file123.txt.
Is it possible to transfer that file directly, so without having to navigate to directory /home/bart/dir1/dir2 and then search that specific file in the list of files?
regards,
Bart
No it's not possible.
Though in the next version (5.8.3), you can easily add an extension that does this.
Save the following code to a file and add it as an extension
https://winscp.net/eng/docs/ui_pref_commands#extensions
<Edited by admin>
Code moved to https://winscp.net/eng/docs/library_example_download_clipboard
bheinsius
i get:
Error: Exception setting "Path": "Cannot find path 'C:\Users\bheinsius\Downloads\WinSCP-20160521r_33e4977-Portable\WinSCPnet.dll' because it does not exist."
Press any key to exit...
Well, you have to store the binaries to the "Program Files". But actually, the 5.8.3 was released meanwhile, so just install it.
This extension has its own page now:
