Topic "WebDAV not working"
anonymous234234
I am trying to connect to a WebDav connection and getting an endless loop of failed authorizations until it crashes. I've attached the log here with private details obfuscated. I am trying to use windows authentication for a domain and username that is different from the currently logged in user....could that be to blame?
I am currently using 5.8.3RC (Build 6701) as I believe this may be related to the following bugs:
http://winscp.net/tracker/show_bug.cgi?id=1397
http://winscp.net/tracker/show_bug.cgi?id=1420
webdavlog.txt (18.63 KB) Private file
Description: log
anonymous234234
just to add - i truncated the logs as it just repeats the failures over and over but let me know if youd like a more complete log
Can you try 5.7.7 for a comparison?
anonymous234234
Same behavior, authentication repeatedly fails. If I try access with a web browser or map a network drive it works, credentials are fine.
Can you capture the traffic for the browser/drive mapping? E.g. using wireshark?
