Topic "Synchronization loops copying remote 0-length file to local"
klausner
Using WinSCP and logging on through an intranet (internal LAN, no internet WAN required). When a remote sub-directry in a directory tree contains a zero-length file (/dev/zero), and I start a synchronization (remote to local) of the top directory, this file is copied forever.
So far I've never heard about /dev/zero file. But reading about it now it seems that what you experience is natural consequence of the file properties. It seems that the file is not zero-length, it is endless. Correct me if I'm wrong.
BTW, solution would be to add the file to exclusion list.
klausner
What is an endess file?
An "ls -l" of "/dev/zero" reports
0 crw-rw-rw- 1 root root 1, 5 Dec 8 2003 zero
/dev/zero is certainly treated as endless by WinSCP, as I have experienced. But with a zero length reported by both Linux and Windows, why would WinSCP treat it as endless? Sould it not treat it just like it would treat a non-existent filename that has been "touch"ed and thereby created?
David
The /dev/zero file is endless source of zeroes.
Note that WinSCP disregards the file size. It must, as for most OS'es the directory listing file size is informational only and may not be accurate. Particularly SFTP specification says:
Quote:
The 'size' field specifies the size of the file on disk, in bytes. If it is present during file creation, it SHOULD be considered a hint as to the file's eventual size.
Sorry, the quote from SFTP specification is irrelevant.
Maybe one obvious note: /dev/zero is not a file, it is device (program). The device, when read produces endless stream of zeroes. As a consequence WinSCP never encounters it's end-of-file.
You can try to do "cp /dev/zero tempfile" on your server. You will end with full filesystem Smile
klausner
Yes, you are right, it is a device and the cp produces an endless stream of bytes. I will add "*/dev/zero" (I assume that's the format based on the WinSCP Documentation) to the exclusion list.
Thank you.
David
klausner
Dear Martin,
Synchronizing directories that contain "zero" and "null" endless files cause WinSCP to never complete. I know that these are "endless" files, but I have created a preset to exclude them, and the exclusion does not work. My preset exclusion is as follows:
"*.bak; *.tmp; ~$*; *.wbk; *~; #*; .#* zero null"
Can you assist me?
David
You need to separate masks with semicolon.
klausner
Dear Martin,
I have separated the masks with semicolons ... it still tries to synch the /dev/null and /dev/zero.
mask=(without quotes)
"/dev/null; /dev/zero"
David
klausner
Posted: 25 Sep 2007 13:37
PostSynchronization loops copying remote 0-length file to local
[Reply with quote] [Edit this post] [Delete this post]
Dear Martin,
I think, perhaps, WinSCP should check for zero-length files and not try toi open them -- merely create the same file on output and move on to the next operation. Reading these files and performing a copy seems to lead to trouble.
David
Please a complete comand you use to set the mask.
klausner
without the enclosing quotes,
"*.bak; *.tmp; ~$*; *.wbk; *~; #*; .#*; /dev/null; /dev/zero;"
Maybe problem is elsewhere. After reading the thread from beginning I've noticed that you refer to "preset". Transfer setting presets does not apply for synchronisation! For synchronisation you need to set mask on the synchronization dialog.
That seemed to do it. It's a bit confusing because one can easily assume that the (Text, Binary ...) Presets apply to synchronization (as I did) because the pulldown on the Synchronization window for "Transfer settings" contains choices for (Presets) Text and Binary, as well as for Custom; and also the Configure pulldown takes us to the Presets window! Best to have the synchronization apply the default presets and not require the user to always specify a Custom mask to be applied to each synchronization separately.
Also, how about not trying to copy zero-length files, just "touch" them on the output side of the synchronization?
Presets can be per-directory. So if it would apply for synchronisation too, different settings should/may be applied for each subdirectory being synchronized. It may be confusing too. I do not know what is better.
I do not think, this is right approach. First size of the file in directory listing is informational only. One should not rely on it. The file maybe growing while opened, etc... If fact what WinSCP does is correct. The files you are having a problem with are there exactly for the reason to generate endless stream of bytes. You may have different "zero-length" file that actually generates a sensible (and finite) content.
I understand. How about a "default" preset for synchronization? The user can still change it, but the default can be other than nothing.
There is a configurable default. The default transfer settings still apply to synchronization.
