Topic "Get successful upload response even when transfer is unsuccessful"
hitmand
Hi
I have a script that uploads to an SFTP server. The server it is uploading to is filename driven, meaning that if it receives a file that is an incorrect filename to what it is expecting it automatically rejects it. For some reason winscp is reporting success even if the transfer was in fact unsuccessful due to me purposely sending a file with the wrong filename, so when I log into the SFTP server as expected the file is not there. Does anyone have any idea what the issue could be?
Please see code:
try
write-host "Trying"
# Connect
write-host "connected"
# Upload files
$transferOptions.TransferMode = [WinSCP.TransferMode]::Binary
$transferResult = $session.PutFiles($FullPath, "/inbox/", $False, $transferOptions)
write-host "pushed files"
# Throw on any error
$transferResult.Check()
write-host "error check"
# Print results
foreach ($transfer in $transferResult.Transfers)
# Success or error?
if ($transfer.Error -eq $Null)
$errortest = $transfer | out-string
$errortest2 = $transferResult | out-string
$errortest3 = $transferResult.Transfers | out-string
Write-Host $errortest
Write-Host $errortest2
Write-Host $errortest3
Write-Host ("Upload of {0} succeeded" -f $transfer.FileName)
Move-Item $FullPath $MovedFolder -force
else
Write-Host ("Upload of {0} failed: {1}" -f
$transfer.FileName, $transfer.Error.Message)
finally
# Disconnect, clean up
$session.Dispose()
write-host "session disposed"
stop-transcript
exit 0
catch [Exception]
write-host "In the catch"
Write-Host ("Error: {0}" -f $_.Exception.Message)
stop-transcript
exit 1
hitmand
Hi
The issue has somehow resolved itself. Thank-you for your help anyway.
Regards,
