Topic "With new Let's Encrypt certificate, "Check For Update" failed."
buri
Hi!
I tried to update WinSCP 5.8.2 beta (build 6284) via "Check For Updates" but winscp.net has new Let's Encrypt certificate, so, it's failed because of certification trust. (look attachment)
Description: Error
Is it Windows 10? What build?
I cannot reproduce the problem.
Does your web browser (which one?) trust the new certificate? Try the Edge or Internet Explorer too.
buri
Windows 10 Pro, Version: 1511, OS Build: 10586.318 (I'm updating my OS).
Domain winscp.net in Google Chrome and Internet Explorer which use central "Trusted Root Certification Authorities" is trusted. (look attachment).
That is the weird thing...
Description: (none)
Please try to connect to the https://winscp.net/, as if it were a WebDAV server and attach a Debug-2 level session log file.
buri
Log in attachment.
The main lines:
2016-05-30 15:01:29.965 Doing SSL negotiation.
. 2016-05-30 15:01:30.169 ssl: Verify callback @ 1 => 20
. 2016-05-30 15:01:30.180 ssl: Verify failures |= 8 => 8
. 2016-05-30 15:01:30.214 Chain depth: 2
. 2016-05-30 15:01:30.225 ssl: Match common name 'winscp.net' against ''
. 2016-05-30 15:01:30.235 ssl: Match common name '<www.>winscp.net' against ''
. 2016-05-30 15:01:30.247 Identity match for '': bad
. 2016-05-30 15:01:30.259 ssl: Match common name 'Let's Encrypt Authority X3' against ''
. 2016-05-30 15:01:30.269 Identity match for '': bad
. 2016-05-30 15:01:30.280 ssl: Match common name 'winscp.net' against 'winscp.net'
. 2016-05-30 15:01:30.293 Identity match for 'winscp.net': good
. 2016-05-30 15:01:30.304 Verifying certificate for "winscp.net" with fingerprint cf:11:88:6b:8e:27:f6:09:ea:01:ab:c5:71:df:cc:03:0a:f7:f1:13 and 08 failures
. 2016-05-30 15:01:30.316 Certificate for "winscp.net" matches cached fingerprint and failures
. 2016-05-30 15:01:30.328 Using TLSv1.2, cipher TLSv1/SSLv3: ECDHE-RSA-AES256-GCM-SHA384, 2048 bit RSA
. 2016-05-30 15:01:30.340 Request sent; retry is 0.
winscp.net.log (83.91 KB) [Download]
Description: log
