Topic "Slow upload speed"
lukinhasb
I'm using WinSCP 5.8.3 RC3 (Build 6701)
Upload speed of site.zip (45mb) using WinSCP -> 30kb/s
Upload speed of site.zip (45mb) using Filezilla -> 680kb/s
Both are using FTP connections, No Ecryption mode.
Please attach a full log file from both clients.
kolivansemen
I also have low upload speed! Sad
lukinhasb
Fly, attachments, flyyyy!!
filezilla.log (6.84 KB) Private file
Description: (none)
hostinger-rc1motos.com.br.log (9.22 KB) Private file
Description: (none)
Thanks for the logs. Can you enable TLS in WinSCP to make the sessions identical? I do not expect this to fix the problem, but I just want to remove any differences before starting the investigation. Post new logs then.
lukinhasb
Where do I enable it?
When you select the FTP protocol, you get Encryption box on the right. Select "TLS/SSL explicit encryption" there.
lukinhasb
Allright, I'm using this setting, and I can confirm Filezilla works 10x faster than WinSCP. We can Teamviewer so you can see it yourself if you wish.
Please post the logs with this settings. Both WinSCP (5.8.4) and FileZilla.
malcev
Hi! I have winscp 5.9.2.0
I use SFTP connection.
Upload speed of winscp is 4000KB.
Upload speed of FileZilla is 12000KB.
Why?
malcev
Forget to say that I upload single file.
What logs I have to send to You?
What CPU usage does WinSCP process have while uploading? Does it max a CPU core?
malcev
01-06 at CPU tab in task manager.
And I test today speed - the result is:
Filezilla - stable 10.4-10.8 Mib.
WinSCP - 4000KB - 10000KB. (Not stable upload speed)
Win7 64Bit. File is 2GB.
Script is:
open sftp://Login:Pass@ftp.blah-blah.lv:2223 -hostkey=*
option transfer binary
put -resumesupport=off test.test
