Topic "Connection Timed Out"
Crystina
This is my most current log file
2005-07-31 14:31:21.234 --------------------------------------------------------------------------
. 2005-07-31 14:31:21.234 WinSCP Version 3.7.5 (Build 294) (OS 5.1.2600 Service Pack 2)
. 2005-07-31 14:31:21.234 Login time: Sunday, July 31, 2005 2:31:21 PM
. 2005-07-31 14:31:21.234 --------------------------------------------------------------------------
. 2005-07-31 14:31:21.234 Session name: newjac@sftp.newjac.org
. 2005-07-31 14:31:21.234 Host name: sftp.newjac.org (Port: 22)
. 2005-07-31 14:31:21.234 User name: newjac (Password: Yes, Key file: No)
. 2005-07-31 14:31:21.234 Transfer Protocol: SFTP (SCP)
. 2005-07-31 14:31:21.234 SSH protocol version: 2; Compression: No
. 2005-07-31 14:31:21.234 Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2005-07-31 14:31:21.234 Ciphers: aes,blowfish,3des,WARN,des; Ssh2DES: No
. 2005-07-31 14:31:21.234 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2005-07-31 14:31:21.234 SSH Bugs: -,-,-,-,-,-,-,-
. 2005-07-31 14:31:21.234 SFTP Bugs: -,-,-
. 2005-07-31 14:31:21.234 Proxy: none
. 2005-07-31 14:31:21.234 Return code variable: Autodetect; Lookup user groups: Yes
. 2005-07-31 14:31:21.234 Shell: default, EOL: 0
. 2005-07-31 14:31:21.234 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2005-07-31 14:31:21.234 Cache directory changes: Yes, Permanent: Yes
. 2005-07-31 14:31:21.234 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2005-07-31 14:31:21.234 Alias LS: No, Ign LS warn: Yes, Scp1 Comp: No
. 2005-07-31 14:31:21.250 Looking up host "sftp.newjac.org"
. 2005-07-31 14:31:21.687 Connecting to 66.15.12.228 port 22
. 2005-07-31 14:31:42.562 Failed to connect to 66.15.12.228: Network error: Connection timed out
. 2005-07-31 14:31:42.562 Attempt to close connection due to fatal exception:
* 2005-07-31 14:31:42.562 Network error: Connection timed out
. 2005-07-31 14:31:42.562 Closing connection.
* 2005-07-31 14:31:42.562 (ESshFatal) Network error: Connection timed out
I have another domain with the same server that does WinSCP just fine. But I have tried for over a week to get this one going to no avail. Can you please help me?
It may be firewall issue. Are you able to connect to the server with any other SSH client? Or even TCP/IP client?
