Topic "First time always fails on a specific network and a specific host"
John1969
I'm running into a time out. The problem only occurs on one network trying to connect to a specific host. Like this:
Quote:
. 2016-06-01 11:30:58.659 Looking up host "XXXXXX.XXXXX.XX"
. 2016-06-01 11:30:58.659 Connecting to XXXX:XXX:XXXX:XXX:XXXX:XX:XXXX:XXXX port 22
. 2016-06-01 11:31:19.690 Failed to connect to XXXX:XXX:XXXX:XXX:XXXX:XX:XXXX:XXXX: Network error: Connection timed out
. 2016-06-01 11:31:19.690 Connecting to XXXX:XXX:XXXX:XXX:XXXX:XX:XXXX:XXXX port 22
. 2016-06-01 11:31:19.721 Server version: SSH-2.0-OpenSSH_6.0p1 Debian-4+deb7u4
The issue does not occur on another network and does not occur with another host.
Do you have any idea why this could happen?
John1969
The issue turned out to be an primary DNS setting that pointed to a DNS Server that had not propagated the hostname.
Using an IP-address solved the issue.
