Topic "File protocol SFTP default"
Namrur
Your session file protocol default is SFTP.
It took me some time to find out why I could not login to my FTP account.
Many accounts does not support this protocol. I could login just after changing it to FTP.
Can you change this default, or show some window help that explain what is an SFTP,
and give the suggestion to change it to FTP?
Also please note that the "Save Password" design is very complicated to use.
Can you use just a V check "Keep my password" instead?
When you try to login with SFTP to a server that supports FTP only, you should get a hint to use FTP. If you didn't, please attach a full log file showing that (using the latest version of WinSCP).
How's V check "Keep my password" different to "Save password"?
