Topic "Search recursively download most recent file"
Partridge
I want to make a connection to an SFTP server and download the latest zip-file.
The remote path consists of several directories which contains zip-files.
At the moment the script only downloads zip-files from /Output
But I also want to check the subfolders for example /Output/Work1
How can I accomplish this? see code below:
param (
$localPath = "D:\temp\",
$remotePath = "/Output/"
try
# Load WinSCP .NET assembly
Add-Type -Path "C:\Program Files (x86)\WinSCP\WinSCPnet.dll"
# Setup session options
HostName = "myhost"
UserName = "user"
Password = "password"
SshHostKeyFingerprint = "ssh-rsa 2048 xxx xxx xxx xxx"
try
# Connect
# Get list of files in the directory
$directoryInfo = $session.ListDirectory($remotePath)
# Select the most recent file
$latest =
$directoryInfo.Files |
Where-Object { -Not $_.IsDirectory } |
#$directoryInfo.Files |
#get-childitem -Recurse | Where-Object {$_.Extension -eq ".zip"} |
Sort-Object LastWriteTime -Descending |
Select-Object -First 1
# Any file at all?
if ($latest -eq $Null)
Write-Host "No file found"
exit 1
# Download the selected file
$session.GetFiles($session.EscapeFileMask($remotePath + $latest.Name), $localPath).Check()
finally
# Disconnect, clean up
$session.Dispose()
exit 0
catch [Exception]
Write-Host ("Error: {0}" -f $_.Exception.Message)
exit 1
Partridge
Anyone?
Instead of using $session.ListDirectory($remotePath).Files, use $ession.EnumerateRemoteFiles($remotePath, "*", [WinSCP.EnumerationOptions]::AllDirectories) (5.8.3 RC version only)
https://winscp.net/eng/docs/library_session_enumerateremotefiles
I have changed
Into
$session.EnumerateRemoteFiles($remotePath, "*", [WinSCP.EnumerationOptions]::AllDirectories)
It does not generate an error anymore but does not download a file either.
There are two files on the remote location.
Show us your complete code.
