Topic "get file from SFTP"
sbeltrami
I have a problem because when start script it get file that just in uploading from customer.
I need to get only files from an SFTP server that have timestamp 2 (n) minutes before.
I need a script example.
Regards
Use a file mask with time constraint <2N:
https://winscp.net/eng/docs/file_mask#size_time
sbeltrami
Thank you very much.
Another question, we are in GMT +1 and looking log file the file that is upload in 2016-06-13 9.10 is matched with 2016-06-13 7.10 (-2 because there is a daylight).
What can I do ?
Regards
sbeltrami
I have attached log file and script in private
The file to check data is test.tif.
I have a scritp the get -delete *.tif<2M but it seem that does not work.
Thank You
Get.txt (512 Bytes) Private file
Description: (none)
20160613101809_GestioneFax.log (41.12 KB) Private file
Description: (none)
The file is 08:11:05 GMT, so as of 10:18:09 GMT+2 (08:18:09 GMT), it should be matched by <2N.
Though you are using rather old version of WinSCP. Can you first try with the latest version?
If it still does not work, please post a new log file using the latest version.
