Topic "how do i send "sudo /usr/lib/openssh/sftp-server" in .net"
elrod_johnson
i'm connecting to an ec2 ubuntu server.
winscp works fine in the gui when i set "advanced site settings" > environment > sftp > protocol options > sftp server = "sudo /usr/lib/openssh/sftp-server"
how do i do this in c# .net?
here's the WinSCP.ini section i'm trying to duplicate in .net
[Sessions\ec2-server]
HostName=<ip>
UserName=ubuntu
PublicKeyFile=<ppk filepath>
LocalDirectory=<local dir>
RemoteDirectory=<remote dir>
SftpServer=sudo%20/usr/lib/openssh/sftp-server <<<--- how do i do this in .net
i did see session.AddRawConfiguration, but can't figure out the correct .ini setting
thanks
SOLVED - with help from https://winscp.net/eng/docs/ui_generateurl
the Generate Session URL/Code is a very useful feature.
correct format is:
sessionOptions.AddRawSettings("SftpServer", "sudo /usr/lib/openssh/sftp-server");
not
session.AddRawSettings("SftpServer", "sudo /usr/lib/openssh/sftp-server");
like i was trying
