Topic "Cannot access the file '...wscp9D6C.00283D6C.tmp' because it is being used by another process"
tmcnairbledsoe
I have seen this error posted before but there does not seem to be a public resolution to the issue. It occurs when opening a connection. Here is the code and a call stack:
Using session As New Session
                session.Open(sessionOptions)
                Parallel.ForEach(imageList, Sub(imagePath)
                                                ProcessWinScp(imagePath, session, transferOptions)
                                            End Sub)
            End Using
Here is where I initialize session options
            With sessionOptions
                .Protocol = Protocol.Ftp
                .HostName = xx
                .UserName = xx
                .Password = xx
            End With
    mscorlib.dll!System.IO.__Error.WinIOError(int errorCode, string maybeFullPath) Unknown
    mscorlib.dll!System.IO.FileStream.Init(string path, System.IO.FileMode mode, System.IO.FileAccess access, int rights, bool useRights, System.IO.FileShare share, int bufferSize, System.IO.FileOptions options, Microsoft.Win32.Win32Native.SECURITY_ATTRIBUTES secAttrs, string msgPath, bool bFromProxy, bool useLongPath, bool checkHost) Unknown
    mscorlib.dll!System.IO.FileStream.FileStream(string path, System.IO.FileMode mode, System.IO.FileAccess access, System.IO.FileShare share) Unknown
    mscorlib.dll!System.IO.File.Open(string path, System.IO.FileMode mode, System.IO.FileAccess access, System.IO.FileShare share) Unknown
    WinSCPnet.dll!WinSCP.SessionLogReader.OpenLog() Unknown
    WinSCPnet.dll!WinSCP.SessionLogReader.DoRead() Unknown
    WinSCPnet.dll!WinSCP.SessionLogReader.Read(WinSCP.LogReadFlags flags) Unknown
    WinSCPnet.dll!WinSCP.CustomLogReader.TryWaitForNonEmptyElement(string localName, WinSCP.LogReadFlags flags) Unknown
    WinSCPnet.dll!WinSCP.CustomLogReader.WaitForNonEmptyElement(string localName, WinSCP.LogReadFlags flags) Unknown
    WinSCPnet.dll!WinSCP.Session.Open(WinSCP.SessionOptions sessionOptions) Unknown
tmcnairbledsoe
Any assistance? This seems like a simple issue that needs to be resolved.
Please attach a full debug log file showing the problem (using the latest version of WinSCP).
To generate log file, set Session.DebugLogPath. Submit the log with your post as an attachment. If you do not want to post the log publicly, you can mark the attachment as private.
tmcnairbledsoe
Any path I pass in to that property throws an unauthorized access exception. Any advice? This is my local machine so I don't see why this should happen. I am admin.
Do you set it to a path to a directory (wrong) or file (correct)?
tmcnairbledsoe
You got it, good call. I've privately attached the log file. As a side question, can WinSCP handle being used by multiple threads?
WinScpLogs.txt (27.13 KB) Private file
Description: (none)
The .Open succeeded in this case. Did you still get the error? When? When calling the .PutFiles? Can you post a matching callstack and a log file?
WinSCP .NET assembly can be called from multiple threads. But it will block, when used in parallel.
tmcnairbledsoe
    > WindowsApplication1.exe!WindowsApplication1.Form1.Button2_Click(Object sender, System.EventArgs e) Line 117 Basic
    System.Windows.Forms.dll!System.Windows.Forms.Control.OnClick(System.EventArgs e) Unknown
    System.Windows.Forms.dll!System.Windows.Forms.Button.OnClick(System.EventArgs e) Unknown
    System.Windows.Forms.dll!System.Windows.Forms.Button.OnMouseUp(System.Windows.Forms.MouseEventArgs mevent) Unknown
    System.Windows.Forms.dll!System.Windows.Forms.Control.WmMouseUp(ref System.Windows.Forms.Message m, System.Windows.Forms.MouseButtons button, int clicks) Unknown
    System.Windows.Forms.dll!System.Windows.Forms.Control.WndProc(ref System.Windows.Forms.Message m) Unknown
    System.Windows.Forms.dll!System.Windows.Forms.ButtonBase.WndProc(ref System.Windows.Forms.Message m) Unknown
    System.Windows.Forms.dll!System.Windows.Forms.Button.WndProc(ref System.Windows.Forms.Message m) Unknown
    System.Windows.Forms.dll!System.Windows.Forms.Control.ControlNativeWindow.OnMessage(ref System.Windows.Forms.Message m) Unknown
    System.Windows.Forms.dll!System.Windows.Forms.Control.ControlNativeWindow.WndProc(ref System.Windows.Forms.Message m) Unknown
    System.Windows.Forms.dll!System.Windows.Forms.NativeWindow.DebuggableCallback(System.IntPtr hWnd, int msg, System.IntPtr wparam, System.IntPtr lparam) Unknown
    [Native to Managed Transition]
    [Managed to Native Transition]
    System.Windows.Forms.dll!System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(System.IntPtr dwComponentID, int reason, int pvLoopData) Unknown
    System.Windows.Forms.dll!System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(int reason, System.Windows.Forms.ApplicationContext context) Unknown
    System.Windows.Forms.dll!System.Windows.Forms.Application.ThreadContext.RunMessageLoop(int reason, System.Windows.Forms.ApplicationContext context) Unknown
    Microsoft.VisualBasic.dll!Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.OnRun() Unknown
    Microsoft.VisualBasic.dll!Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.DoApplicationModel() Unknown
    Microsoft.VisualBasic.dll!Microsoft.VisualBasic.ApplicationServices.WindowsFormsApplicationBase.Run(string[] commandLine) Unknown
WinScpLogs.txt (11.52 KB) Private file
Description: (none)
How do you catch that exception?
That cannot be an exception caught outside of the .Open call matching the debug log file.
If you take a look at the WinsCP .NET assembly source code, you will that there's try .. catch block around whole method, where the catch block logs an exception, if any. There's no exception in the log.
tmcnairbledsoe
I get it from the debug exceptions break list. Not sure if that helps.
Not sure what that. What I'm basically asking, if you get the exception at the point it is thrown in the WinSCP code, or if you get it outside of WinSCP code. If the first, you probably have enabled breaking on exception throwing. But most (all) instances of that exception will be handled. So you are not interested in those.
Anyway, this should not occur in 5.8.x anymore.
