~ and ~username are not processed
goldan
Warszawa
There is an error No 2 thrown "No such file" when attempting to use "~" in the remote side recycle bin path.
In particular, I defined remote trash directory as "~/trash/" or "~usename/trash/". This setting resides in "Advanced Site Settings::Environment::Recycle bin". In both cases it does not work.
Using SFTP. Need more details - let me know.
Pathduck
Pathduck avatar
Oslo
By the way just FYI, if you change protocol to SCP I think it might work as SCP seems to understand the meaning of tilde.
Might or might not work for you, SCP is usually a lot slower than SFTP in my experience.
cheers
Stian
