Topic "WinSCP Putty Port"
kkkkkkkkkkkk
There is no pattern for port in Putty command line options so if you use WinSCP to open Putty Portable, it won't work.
Currently: PuTTYPortable.exe !U@!@
Should be: PuTTYPortableLinker.exe !U@!@ -p !X (!X or something else which gets replaced with the port of the WinSCP site)
Thank you
kkkkkkkkkkkk
Edit: It will work for standard ssh port 22 but for non default ports, it won't.
Since the 5.8.x, you can use the !#:
https://winscp.net/eng/docs/ui_pref_integration_app#client_path
This request is tracked here:
https://winscp.net/tracker/show_bug.cgi?id=1020
