Topic "Problem with put"
p1c0
Hi all,
i have difficulties with put...
I try winscp /console /script=script.sh where script.sh is :
option batch on
open root@192.168.1.185:22
option transfer binary
cd /etc/rc.d/init.d
! rm -f iptables
put path_to_file/iptables
but it doesn't work, winscp said it can't find my file path_to_file/iptables.
How can i resolve my problem?
Thanks in advance.
p1c0
p1c0
Sorry,
i have just find the lcd command, it will work with this command!!
p1c0.
p1c0
Finally, i have a problem...
When i put a script on a linux box with WinSCP interface, it works perfrctly and i can execute the script locally on the linu box. But when i put the same script with
option batch on
cd /etc/rc.d/init.d
! rm -f iptables
i can't execute the script locally. I have some interprter problems...
I try a "diff file1 file2" and all lines of my script seems to be different but there is no visible changes...
Could you help me please?
I'm confused by your message. What do you refer to by "script"? script.sh or some file you are transferring?
p1c0
Sorry, i try to put an other script in order to configure iptables so it's a file i want to transfer...
p1c0
I have found my problem : my file is in DOS format, so there are \r\n at end of lines.
I have to find how to translate my file in unix format, i've seen dos2unix on the net... i will try this!!!
Use 'option transfer ascii' to enable on-transfer conversion.
