Topic "exit code 1 with succesfull transfert in batch script"
maxfranco
i'm using a batch script to transfer a big file (about 20GB)
this is the command i use in the batch file:
winscp.com soyoustart /log="%winscplog%" /command "put %warc-bkup%" "exit"
this is the report of the log file:
. 2016-06-23 01:27:28.811 Transfer done: '\\cscs3\winarc_bkup\CSCWARC_db_201606220200.BAK' [20925847040]
> 2016-06-23 01:27:29.306 Script: exit
. 2016-06-23 01:27:29.320 Script: Exit code: 1
. 2016-06-23 01:27:29.418 Closing connection.
. 2016-06-23 01:27:29.420 Sending special code: 12
. 2016-06-23 01:27:29.426 Sent EOF message
the resulting errorlevel is ever 1.
what i'm doing wrong? Sad
See https://winscp.net/eng/docs/faq_exit_code
maxfranco
sorry for the delay...
the only command that report a status 1 is the exit command, as showed in the log:
2016-07-11 01:24:00.868 Status code: 0
. 2016-07-11 01:24:00.870 Transfer done: '\\cscs3\winarc_bkup\CSCWARC_db_201607100200.BAK' [20975201792]
> 2016-07-11 01:24:01.240 Script: exit
. 2016-07-11 01:24:01.251 Script: Exit code: 1
. 2016-07-11 01:24:01.435 Closing connection.
. 2016-07-11 01:24:01.436 Sending special code: 12
. 2016-07-11 01:24:01.439 Sent EOF message
can i safely remove the exit command?
but.. why the exit command report an error? all examples i saw used "exit" at the end of the command string.
It's not the exit command. Show us a complete log file.
