Topic "webdav access help needed"
I have access to a webdav with WinSCP UI. No problem there. See png. I use following code snippit:
(It probably has something to do with TSL/SLL encryption, but I do not know what tot do)
Thank you for any help. Marc
    With sessionOptions
       .Protocol = Protocol.Webdav
       .HostName = "xxx.xxxxx.xx"
       .PortNumber = 443
       .WebdavRoot = "/xxx/"
       .UserName = "xxx"
       .Password = "xxx"
    End With
 Using session As New Session
I Get the following error:
WinSCP.SessionRemoteException: Could not read status line: connection was closed by server ---> WinSCP.SessionRemoteException: Connection failed.
2016-07-02 09_48_51-Clipboard.png (19.06 KB)
Description: (none)
To enable TLS, you have to set the .WebdavSecure = True, not the .PortNumber.
The best way is to have WinSCP generate the code for you:
