Topic "Help required with logging and files not being posted.\"
sharoz
i am using below code for transferring files to WinSCP. "SourcePath" are the directories,"SourcePathRecordings" are the files contained in those directories and there are almost 100 files in each directory. The issue i have been encountering is
1. sometimes the files doesn't get posted, if there are 100 files in the directory only 40-50 get posted although i have the loop on each file.
2. I want to enable WINSCP logging, and i want the log file to save on the local system. how would i do that?
Urgent help will be highly appreciated! Rolling Eyes
for (int a = 0; a < SourcePath.Length; a++)
string[] SourcePathRecordings = Directory.GetFiles(SourcePath[a]);
for (int i = 0; i < SourcePathRecordings.Length; i++)
string CommandText = "";
CommandText += @"/command ""option batch abort"" ""option confirm off"" ""Open """"" + SFTPAddress;
CommandText += @""""" -passive=on"" ""Put """"" + SourcePathRecordings[i];
CommandText += @""""" """"" + TargetPath + @"""""";
CommandText += @""" ""close"" ""exit"" ";
Process winscp = new Process();
winscp.StartInfo.FileName = @"C:\WinSCP3\WinSCP.exe"
winscp.StartInfo.Arguments = CommandText;
winscp.StartInfo.UseShellExecute = false;
winscp.StartInfo.RedirectStandardInput = true;
winscp.StartInfo.RedirectStandardOutput = true;
winscp.StartInfo.CreateNoWindow = true;
winscp.StartInfo.ErrorDialog = true;
winscp.WaitForExit();
winscp.Close();
c++;
To enable logging, use /log=c:\path\winscp.log command-line parameter.
Though I highly recommend you to use WinSCP .NET assembly, instead of trying to run winscp.exe yourself.
sharoz
i tried using the assembly too but the issue remains same if there are 75 files in my folder and i post them one by one only 10-15 files gets posted.
sharoz
Martin,
i am trying to copy files over the network through winscp. I am using the assembly as per your advice. there are 100 folders on my root directory and each folder contains 100-150 files. i have attached the session log, I am getting connection time outs for all my session. Could you please help me with this?
winsp08.12.2016.log (25.98 KB) Private file
Description: Session Log
Sorry, I have no idea why the server keeps disconnecting you. It looks like a server-side bug.
