Topic "Stop transfer in FileTransferProgress Event"
bpacilio59
I sometimes have large downloads or uploads that may need to be interrupted. Can I stop the transfer from withing the FileTransferProgress event ? I don't want to end the session, I just want to stop the current tranfer
No, this is not supported. Ending session is the only way.
bpacilio59
Given this is the only way, I would be ending the session from the FileTransferProgess Event. Would I be better off using the session->close or the session->abort ?
Use the Abort. The Close won't work.
Barlo
I'm using session.SynchronizeDirectories, but sometimes is needed stop the transfer. The issue is that I dont't know how to use session.abort. I have added a new button to the form to implement the stop funcionality.
Could you please write an example of this?
Thanks.
Sorry, but we are not a code writing service here.
Barlo
Thank you Martin,
In that case, could you please, give me some idea, using words, about how to use session.abort in the middle of a transfer so it takes effect?
Thank you in advance.
I do not understand the question. Just call it. From another thread. Or from some event handler.
